Exhaust - power
Re: Exhaust - power
Postby underscore » Wed Nov 11, 2015 4:49 pm
It should rise to ~10psi in 3/4/5 gear so it sounds like your TVSV is disconnected or broken. If you have a 3" downpipe and a 3" axleback I'd get a 3" midpipe made to keep the flow smooth and have an extra resonator or muffler put in it as needed to keep the sound where you want it.
Re: Exhaust - power
Postby Rallly » Wed Nov 11, 2015 5:25 pm
underscore wrote:It should rise to ~10psi in 3/4/5 gear so it sounds like your TVSV is disconnected or broken. If you have a 3" downpipe and a 3" axleback I'd get a 3" midpipe made to keep the flow smooth and have an extra resonator or muffler put in it as needed to keep the sound where you want it.
How do I check my tvsv? I've checked everything else with no luck.
Rallly
Re: Exhaust - power
Postby Rallly » Wed Nov 18, 2015 3:39 pm
Wouldn't a resonator or extra muffler "bottle neck" my exhaust, preventing better turbo performance?
Rallly
Re: Exhaust - power
Postby underscore » Tue Nov 24, 2015 3:01 am
Not really, since 3" is already a little larger than the car needs. Regardless you have to make the compromise one way or the other, for completely undisturbed flow you're going to have a very loud (and usually illegal) car, for a reasonable volume you have to add mufflers and resonators but the loss of power (if any) is so minor you won't be able to tell.
Re: Exhaust - power
Postby Rallly » Tue Nov 24, 2015 10:59 am
So with a 3 inch exhaust system front to back, what size resonator should I place in the system?
Rallly
Re: Exhaust - power
Postby underscore » Tue Nov 24, 2015 3:21 pm
Anything that fits and has a 3" inlet/outlet would work.
Re: Exhaust - power
Postby Rallly » Tue Nov 24, 2015 5:56 pm
Cool :) I'm just hoping it won't be obnoxiously loud..
Rallly
Re: Exhaust - power
Postby Rallly » Mon Feb 15, 2016 12:07 am
Hey guys, I ended up going 2.5 exhaust straight to the back, dp, mp, and boost seems to want to surpass 13-14 and beyond. I will be installing a fcd shortly cuz I am very easily hitting cut but I worry that I will still be overboosting past my turbo threshold of 14psi after the fcd... What should I do so I don't go passed 14? Is this even normal after exhaust work?
Rallly
