Mech Boost gauge install
Postby Rallly » Fri Oct 02, 2015 11:31 pm
Hey, okay so the pictures in the "HOW TO" boost gauge install section are not working for me. I'm unsure of which oem vac hose I need to tee into to install my mechanical boost gauge. Also can I use a silicone or rubber hose instead of the nylon one? I bought my gauge used and there is no nylon hose.
Thanks!
Rallly
Re: Mech Boost gauge install
Postby CMS-GT4 » Sat Oct 03, 2015 1:27 am
I'll have an answer about the nylon hose by Monday. I ordered a barb to use silicone instead.
Postby Rallly » Sat Oct 03, 2015 1:08 pm
Sounds good:)
quote="CMS-GT4"]I'll have an answer about the nylon hose by Monday. I ordered a barb to use silicone instead.[/quote]
Rallly
Postby slakeco » Sat Oct 03, 2015 2:33 pm
I'm no authority on anything mechanical, but I had the hood open already and wanted to try to help.
I hope this helps. If someone can confirm, that'd be helpful.
slakeco
Postby underscore » Sat Oct 03, 2015 5:32 pm
I'm just using whatever standard vacuum line is made of for mine, just remove a cap from one of the extra ports on the back of the intake manifold and hook up to that.
Postby Rallly » Sat Oct 03, 2015 5:42 pm
Thanks man, I don't think my stock Alltrac has a BOV though?
slakeco wrote:I'm no authority on anything mechanical, but I had the hood open already and wanted to try to help.
Rallly
Postby Mr Alltrac » Sat Oct 03, 2015 8:02 pm
Highly doubt it. St205 came with a bpv (bypass valve) but neither the 165 or 185 had one.
Mr Alltrac
Postby CMS-GT4 » Sat Oct 03, 2015 9:20 pm
underscore wrote:I'm just using whatever standard vacuum line is made of for mine, just remove a cap from one of the extra ports on the back of the intake manifold and hook up to that.
This is the most common hook up point. I am using an unused port on the manifold, but I may be changing it after some upcoming testing. I got data from an electronic sensor and found my boost gauge is not correct.
Postby underscore » Sat Oct 03, 2015 9:26 pm
What makes you say that it's incorrect? Ideally you want it to read from the same source as the sensor for fuel cut since that's the biggest worry.
Postby Rallly » Sat Oct 03, 2015 11:13 pm
Okay so where is the most accurate place to tee into??
Rallly
Postby CMS-GT4 » Sun Oct 04, 2015 8:12 pm
underscore wrote:What makes you say that it's incorrect? Ideally you want it to read from the same source as the sensor for fuel cut since that's the biggest worry.
It reads a different vacuum and max boost as my map sensor is detecting. I looked at it, and saw that it is not zeroing when off. It rests on a few psi, which might explain why it reads low on vac and high on boost. Once I zero it, if it does not match up, I will experiment with places to hook up for readings.
On a note of the hook up, they sent the wrong size... so I will have to wait till a new one comes in.
Postby Rallly » Sun Oct 04, 2015 11:50 pm
Wrong size hose?
Rallly
Postby CMS-GT4 » Mon Oct 05, 2015 12:11 am
Wrong size thread that goes to the back of the boost gauge.
Postby Rallly » Tue Oct 06, 2015 4:56 pm
Where else can I tee into my stock st185 celica? I had a look between the firewall and intake and only noticed 1 rubber hose coming off the intake but it's a bigger diameter hose then I am using on my boost gauge. I would like to tee into an accurate source that uses a 4mm hose. Any ideas?
Rallly
Postby Rallly » Wed Oct 07, 2015 10:29 pm
Any places on the throttle body?
Rallly
