1990 Celica Alltrac Timing Belt Kit
Postby Mr Alltrac » Sun Nov 29, 2015 4:16 am
So thanks to msanders, I'm motivated to get my st185 running again. I'm in need of a timing belt kit with pulleys, belt, and water pump.
Where can I find one?
Mr Alltrac
Re: 1990 Celica Alltrac Timing Belt Kit
Postby msanders2 » Sun Nov 29, 2015 4:49 am
I use worldpac. They sell Oem parts. I just added up all the parts to do the T belt and seals on the sw20 I bought and it came out to about $200. That's with cam seals, crank seal, water pump, t belt, tensioner, tensioner idler, and idler pulley.
Postby yyonline » Tue Dec 01, 2015 3:00 am
A kit doesn't exist, at least not a good one. However, you can buy all the parts separately and for less than the dealer charges.
Water pump: Aisin WPT-056. Available at RockAuto, Amazon, etc.
Timing belt idler pulley is Koyo PU355816RR9D which is Worldpac P/N W0133-1631471: http://www.amazon.com/Koyo-Timing-Belt- ... k-c1514-20
Tensioner pulley is Koyo U00392B. Available at Amazon.
Mitsuboshi timing belt is Worldpac P/N W0133-1630981: http://www.amazon.com/Mitsuboshi-W0133- ... k-c1514-20
