FORGE mbc install help
Postby Rallly » Wed Jan 20, 2016 2:47 am
Hello, I just bought a used FORGE mbc, it has 2 nipples. One off the side and one off the bottom. Can someone please post a picture or link to show me how/where to install this to my 91 AllTrac please. Thank you :)
Rallly
Re: FORGE mbc install help
Postby quieter » Wed Jan 20, 2016 3:22 pm
from your turbo theres a nipple on the side of your air intake, connect a air hose from that nipple to the bottom of your MBC then connect another air hose from the side of your MBC to your wastegate which controls the valve in your turbo. do not forget to block off the other nipple going towards the driver on the wastegate with a blank
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Rallly » Wed Jan 20, 2016 6:13 pm
Gr8 thanks!
Will be doing a full 3 inch exhaust this weekend. I wonder what I'll boost to from just doing that?
Rallly
Postby quieter » Wed Jan 20, 2016 7:34 pm
there will be less restriction because you are changing your exhaust, on a 2nd gen go for max 14 psi
-Simon
quieter
Postby Rallly » Wed Jan 20, 2016 8:25 pm
quieter wrote:there will be less restriction because you are changing your exhaust, on a 2nd gen go for max 14 psi
Thanks for your knowledge sir:)
Yup yup, do you recommend 2.5inch or 3" exhaust front to back? Will follow with a MBC afterwards, just looking for a reliable 14psi. Currently stuck at OEM 8psi~.
Also I read about needing a brace for the dp otherwise I risk cracking it... Is this legit? Should I brace it to the motor or have it cut and add a flex pipe in the middle of the dp?
Rallly
Postby quieter » Wed Jan 20, 2016 8:39 pm
better off adding a flexi or getting a berk downpipe. id go 3 inch all the way in case you want to do big power one day. careful with the ebay dp i heard the wastegate can get stuck on them. also be careful with 14 psi, your headgasket may fail one day.
-Simon
quieter
Postby Rallly » Wed Jan 20, 2016 10:38 pm
quieter wrote:better off adding a flexi or getting a berk downpipe. id go 3 inch all the way in case you want to do big power one day. careful with the ebay dp i heard the wastegate can get stuck on them. also be careful with 14 psi, your headgasket may fail one day.
Flexi it is:) I don't plan to add huge power. It's just my daily driver so just freeing up some hidden potential:) I purchased the eBay Autobahn88 dp and grinded about 1mm of material. Will I be okay?
Rallly
Postby Rallly » Wed Jan 20, 2016 10:42 pm
quieter wrote:from your turbo theres a nipple on the side of your air intake, connect a air hose from that nipple to the bottom of your MBC then connect another air hose from the side of your MBC to your wastegate which controls the valve in your turbo. do not forget to block off the other nipple going towards the driver on the wastegate with a blank
Where you said "turbo theres a nipple on the side of your air intake," you mean the only nipple on the turbo housing right?
Rallly
Postby quieter » Fri Jan 22, 2016 3:05 am
it should be ok for the DP and yeah exactly that nipple!!
-Simon
quieter
Postby Rallly » Fri Jan 22, 2016 3:17 am
quieter wrote:it should be ok for the DP and yeah exactly that nipple!!
Thanks man. Decided to go 2.5inch to keep noise down and not going to go past 300hp so no point. I'll install the mbc once I see what I'm boosting after exhaust job;)
Rallly
Postby Rallly » Wed Jan 27, 2016 3:33 pm
So exhaust went on yesterday and it's pushing strong now:) I was stuck at 8psi and I saw it raise to 13.5ish psi without any other mod than straight through 2.5inch exhaust. Is this normal? Was able to really test WOT in every gear cuz of icy conditions but I guess it's safe to say I don't need to install a mbc
Rallly
Users browsing this forum: Bing [Bot] and 3 guests
