gen 3 MR2 ECU running ST185
Postby Smaay » Mon Feb 29, 2016 12:26 am
has anyone used a gen 3 MR2 ECU to run their car? the engine already has ST205 injectors. it looks like the MR2 has more sensors. will I be fighting a CEL?
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: gen 3 MR2 ECU running ST185
Postby zaluss » Mon Feb 29, 2016 12:43 am
Smaay wrote:has anyone used a gen 3 MR2 ECU to run their car? the engine already has ST205 injectors. it looks like the MR2 has more sensors. will I be fighting a CEL?
Not sure if this helps but I use a gen3 MR2 ecu for my swap to defeat the pump code but I have a ST165. No codes.
zaluss
Postby Smaay » Mon Feb 29, 2016 1:08 am
that is good news, anyone else?
97 Supra 2JZ-GTE
Smaay
Postby CTechBlueDragon » Mon Feb 29, 2016 1:20 am
No you won't have to fight any CEL. The re-pin is fairly simple only like 5 wires if I remember correctly.
CTechBlueDragon
Images: 51
Postby Smaay » Wed Mar 16, 2016 4:05 pm
looking at this pinout and looking at 93 All-Trac engine control I have to change 2 pins!!!! thats it 2 pins.
Move FPR pin A-6 to C-16
Move PIM pin C-5 to C-2
It cant possibly be that easy
97 Supra 2JZ-GTE
Smaay
Postby underscore » Wed Mar 16, 2016 4:44 pm
You also have to repin the engine side to run the new sensors, but I think that's about it. There's a few threads on here about it.
Postby klue » Wed Mar 16, 2016 4:59 pm
wont have any issues, ive done it a few tims for st205 engine swaps without the WTA system
Postby Smaay » Thu Mar 17, 2016 1:11 am
underscore wrote:You also have to repin the engine side to run the new sensors, but I think that's about it. There's a few threads on here about it.
oh hell what new sensors? crap i need a 3rd gen MAP sensor dont I? but what other sensors?
97 Supra 2JZ-GTE
Smaay
Postby Smaay » Sun May 15, 2016 10:59 pm
what new sensors other than the MAP? is there something else I need to change?
97 Supra 2JZ-GTE
Smaay
Postby Smaay » Tue May 17, 2016 10:54 pm
need an answer here
97 Supra 2JZ-GTE
Smaay
Postby underscore » Wed May 18, 2016 4:05 am
Just read the swap threads, should be a few around here.
Postby CTechBlueDragon » Thu May 19, 2016 1:27 am
You need a MAP a MAT and an IAT. Pressure sensor and both air sensors. I think that's about it...
CTechBlueDragon
Images: 51
Postby Corey » Fri May 20, 2016 1:09 am
There are a couple great gen 2 to 3 efi swap threads on www.mr2oc.com
You will need to repin the harness at the ecu or have a jumper harness made by berk technologies.
You'll also need a map, ignitor (rpm limit will be lower if not changed), iat sensor and manifold temp sensor. The mat and iat sensors can be wired into the AFM harness, with these wires being repinned at the ecu.
The mat can take the place of the cold start injector using an adapter plate.
You mentioned you already have 205 injectors.
I think that's all, I did this swap 4 years ago and it was the best upgrade I've ever done.
Corey
Images: 50
Postby alltracman78 » Sat May 21, 2016 2:32 am
Easier to use the EGR wiring for the MAT sensor IMO.
It's 1 extra wire to swap at the ECU but that's easier than running the AFM wiring to the intake manifold.
If you have a 92/93 harness it's only a few wires [5?]. No need for a jumper.
I have a brand new Toyota harness and I didn't want to cut it up so I used O2 sensor wires to connect the new sensors to the existing harness.
IAT is the same one for the 5SFE and 7AFE. Igniter is the same as the newer 96^? 5SFE.
Postby Smaay » Sun May 22, 2016 5:06 am
I already wired up an IAT in the intake manifold. car is running an an AEM V1 now. what signal is the MAT? Manifold temp?
97 Supra 2JZ-GTE
Smaay
