1991 AT Engine Disassembly And Reassembly
Postby Il_Barone » Tue Apr 05, 2016 3:05 pm
Hope to be in the right section.
4 months ago my engine block crancked near the water pump.
Reding this forum i found out that is a common problem of this type of engines, so i found an used Rev2 block and last sunday we started to disasembly the old 3sgte.
Here it is:
I've already ordered this kit: 86.5 CP Pistons kit, Eagle Rods, Arp Head Studs and the MLS head gasket (standard size)
In the next days i'll publish updates :)
Any advice is welcome :)
Have a nice day
Daniele
Il_Barone
Re: 1991 AT Engine Disassembly And Reassembly
Postby Il_Barone » Mon Sep 19, 2016 3:17 pm
Update:
My setup is:
Gen2 head with Gen3 camshafts
Gen2 block with:
- Cometic steel head gasket (thick as the original stock)
- CP pistons (86,5mm diameter)
- Eagle rods
- ACL complete bearing set
- Stainless Steel exhaust system
- Crankshaft and flywheel balanced
I'd like to keep the original ECU. What is your opinion about? :)
I'm not planning any boost level increase.
Now i'm looking for the spark plugs, i think i'll buy 4 NGK BKR6EP8.
I can't find the Denso plugs anywhere.
Here there are some pics of the new engine:
Any advise is welcome :)
Daniele
Il_Barone
Postby zedxfarin » Fri Sep 30, 2016 2:03 pm
The is inspiring!! :notworthy:
I Will be following :)
YES I KNOW I HAVE NO SIGNATURE!!!
zedxfarin
Postby awdmofo » Fri Sep 30, 2016 8:35 pm
im actually doing the same thing starting this weekend :D excited to crack this used engine open and see how bad it is compared to my already blown one. How long do you think it will take you do clean everything up and put it back into the car? Are you going to replace the clutch/flywheel while its apart?
viewtopic.php?f=44&t=51613
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
Postby ST185l » Sat Oct 01, 2016 7:34 pm
wow, could put photos cranked, I have never seen any and if it is a common mistake ... you'd better be forewarned
It is a common error in 1/3 and 4 gene?
I could tell what has cost kit pistons reconstruction, etc. I'm in a similar situation and would like to forge better quantify whether or not forge
Bearing set is part of the kit or purchased separately, if so might know your price?
Where he bought all materials / parts, know if you ship to Spain?
What improvement or how much improvement expected from the camshafts 3 gene
A great job, muchisimos encouragement and thanks for sharing with us.
I hope these advances
ST185l
Postby GT4times2 » Sun Oct 02, 2016 6:16 pm
IF you're not going to modify the car much, the stock ECU should be Ok. But fuel, cams, turbo upgrades...... :nono:
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby Il_Barone » Mon Feb 20, 2017 12:02 pm
Something is moving, very slowly :)
Yesterday night we mounted the intake manifold, injectors and the wiring.
Anyway, i noticed for the first time a modify on the turbo, here it is:
There are two pipes, one on the front (in the picture, where the metal cover is cut) and one on the back of the CT26.
What do you think it is, a custom water-cooling modify?
Ciao! :)
Il_Barone
Postby Il_Barone » Wed Mar 01, 2017 10:15 am
Is there any moderator who can move this topic to "my project"?
Maybe it's the correct section.
Thank you
Il_Barone
Postby awdmofo » Sat Mar 04, 2017 5:30 pm
nice!! you lied on my build page, you're way ahead of me in my build :D. Machine shops still has my block and working on the head next week. What flywheel/clutch did you go with? Any reason you don't want a CT-20B turbo or something more fun? with some fuel upgrades and a customer computer you can make that engine fly :shock:
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby Il_Barone » Thu Mar 09, 2017 3:57 pm
It works!
First, we run the engine without the coil to put the oil (Castrol Magnatec) in circulation, then we connected the coil and it turned on at the first try :)
Maybe tomorrow evening we'll do the first ride after a long time, we still mount one driveshaft boot and new tires.
Here there's a picture of the engine complete and one of another friend of ours (in addition to the forklift)
Il_Barone
Postby Il_Barone » Thu Mar 09, 2017 4:15 pm
awdmofo wrote:nice!! you lied on my build page, you're way ahead of me in my build
We started the job one year ago, more or less :D :D
awdmofo wrote:What flywheel/clutch did you go with?
Original clutch. Original flywheel too, but it's balanced.
awdmofo wrote:Any reason you don't want a CT-20B turbo or something more fun? with some fuel upgrades and a customer computer you can make that engine fly :shock:
First reason is money :D
Second and more important reason is that i'm afraid my new block can crack again.
I don't know why the old block cracked, it was a stock engine always and well mantained. It cracked near the water pump.
About that, any possible suggestions are welcome.
Il_Barone
Postby Il_Barone » Mon Mar 13, 2017 12:17 pm
Bad news guys.
Very bad news.
It leaks coolant from the head gasket. Exactly from the layers of the gasket.
With the engine on, we can see the coolant dripping from that precise point (in the red circle)
We torqued the head bolts following the BGB instructions.
We have not re-torqued them yet. Maybe it's the reason of that leak?
The head gasket is a Cometic with ARP bolts. Block and head were machine-shaped.
Did the same thing happen to you? Or do you know if it's a possible problem with Cometic gaskets?
I'm very demoralized :(
Il_Barone
Postby outinnowhere3193 » Thu Mar 30, 2017 9:47 pm
arp head bolts require more torque if I remember right. you should follow the arp torque specs.
But none the less it shouldn't of leaked at all. I personally always copper coat my gaskets even though cosmetic says no need to do so.
outinnowhere3193
Images: 5
Postby Il_Barone » Fri Mar 31, 2017 11:48 am
We re-torque the head bolts and it doesn't leak anymore!!
We did about 10 km of road test, the engine goes very fast, the Japspeed stainless steel exhaust makes a beautiful sound :D
Next week we'll take the car to the bodyshop for a complete repainting
Pictures coming soon :D
outinnowhere3193 wrote:arp head bolts require more torque if I remember right. you should follow the arp torque specs.
We re-torqued the head (in the ARP box there was no specs about the torque specifications) but we didn't use any gasket sealant.
Il_Barone
Postby Il_Barone » Fri May 12, 2017 2:35 pm
Almost ready
Il_Barone
