Fuel Pressure up mod with manual boost controller????
Postby Camshaft1987 » Sun Apr 10, 2016 6:28 pm
Hey guys. Tried searching forums couldnt find anything. Im using a manual boost controller set at 11psi and want to know if the bleeding boost signal to the controller will affect the boost signal to the FPR. Im planning on teeing off of the line from the compressor to the manual boost controller to get the full 11psi to the FPR. Will the FPR still read the full 11psi or will it drop off because of the bleeding boost signal thanks.
Camshaft1987
