Which O2 sensor with threaded downpipe
Postby clayton351 » Fri May 06, 2016 3:16 pm
So I just picked up my 90 alltrac and it came with a downpipe with a threaded bung instead of the 2 bolt flange. Does anybody know a part number for one that works?
clayton351
Re: Which O2 sensor with threaded downpipe
Postby ___Scott___ » Sat May 07, 2016 2:29 pm
I don't have a part# to suggest, but all narrow band O2 sensors work the same way. The only difference is the connector and sometimes the wire colors. Some have heaters in them so they warm up faster and these will have four wires instead of two.
So, if you are willing to do some wire splicing and already have suitable connectors then you should be able to find something that works.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby CTechBlueDragon » Sat May 07, 2016 3:11 pm
Not sure of the part number but the Caldina 215 motors have the threaded one. I have one that is used if you want it. I am putting a TD06 20G on right now and the downpipe has the 2 bolt style opening welded on it already.
CTechBlueDragon
Images: 50
Postby alltracman78 » Sat May 07, 2016 9:30 pm
1st gen Tundra V8 one works.
The O2 sensor, not the A:F sensor.
