Lightened flywheel
Lightened flywheel
Postby Locker » Tue May 10, 2016 2:19 pm
Hey guys, Just looking for some thoughts and opinions.
In my parts bin I have a lightened flywheel. I am trying to decide whether or not I should use it when I install my Gen4 engine in my car. I've read a lot of conflicting posts on the advantages and disadvantages of running one and curious what you guys think.
The car isn't being built to be a racecar and driveability is a very important component to the build which is why I'm hesitant on using it.
Thanks,
Mike
90 ST185
Locker
Re: Lightened flywheel
Postby underscore » Tue May 10, 2016 4:11 pm
How lightened is it?
Postby mx6er2587 » Tue May 10, 2016 6:19 pm
Both of my tracs came with lightweight flywheels so I've never driven one without one, but compared to all the other manual transmission vehicles I've owned I wouldn't say the driveability is any worse becuase of flywheel mass
mx6er2587
Postby msanders2 » Tue May 10, 2016 9:25 pm
I have the findaza in my car with my gen 2 built stroker. I needed a flywheel to fit the 5sfe crank. I don't like it much. I'm swapping in a gen4 in a couple of months and will be going back to the stock flywheel and selling the fidanza.
msanders2
Postby Locker » Wed May 11, 2016 2:04 am
msanders2 wrote:I have the findaza in my car with my gen 2 built stroker. I needed a flywheel to fit the 5sfe crank. I don't like it much. I'm swapping in a gen4 in a couple of months and will be going back to the stock flywheel and selling the fidanza.
Why don't you like it?
90 ST185
Locker
Postby msanders2 » Wed May 11, 2016 3:24 am
It doesn't feel as "smooth" and a factory weight one. It's hard to explain. My mr2 has the stock flywheel and all around driveability feels better.
msanders2
Postby Locker » Wed May 11, 2016 9:59 am
Thx
90 ST185
Locker
Postby Smaay » Tue May 24, 2016 2:10 pm
i love Fidanza flywheels, so ill be happy to take that off your hands
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Postby msanders2 » Tue May 24, 2016 4:47 pm
Awesome. When I swap my gen4 in I'll let you know
msanders2
Postby klue » Fri May 27, 2016 1:28 pm
Its hard to compare apples to apples in this situation. As most people change the flywheel and the clutch at the same time. Introducing the clutch as a variable.
If your dropping 20lbs off the flywheel with a stage 3 clutch, yes your going to make it a bit tricker to get going
Postby Corey » Fri May 27, 2016 2:55 pm
I've tried two light weight clutch setups in my car. One an ORC, now an ACT HD with light weight flywheel.
Both are very easy to drive. Much better revmatches.
Corey
Images: 50
Users browsing this forum: silverarrow27 and 1 guest
