5sfe block transfer case not fitting
Postby outinnowhere3193 » Mon Jun 20, 2016 2:14 am
Has anyone done the 5s block build? I have a completely pieced together setup and ran into yet another issue again today.
So details on my built is
5sfe block and crank with journals turned to match 3s rods.
Atsracing pistons
Eagle rods
Moroso oil pan
Ats oil pump
Gen 3 head
Gsc s2 cams
Hks sprokets
Id2000cc injectors. Calling ats tomorrow about some adapters
Had some bracket issues I had to alter to make it work.
And finally tonight tried installing the transmission and transfer case. But the transfer case is rubbing the block to much to get it on. Pulled out the grinder to start grinding and my grinder took a crap.
Anyone done a 5s n a alltrac?
outinnowhere3193
Images: 5
Re: 5sfe block transfer case not fitting
Postby mx6er2587 » Mon Jun 20, 2016 4:16 am
you had the right answer. Somewhere there's a thread with pictures of how much needs to be ground away.
mx6er2587
Postby GT4_DRED » Mon Jun 20, 2016 3:29 pm
There's quite a bit of grinding needed to clear the transfer case and depending on the year of the block, you may need to tap it for the support bracket to be bolt on. I added a few pics of what I did in my build thread.
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46750&start=45
'00 SC300 - "The long way home" daily driver
'88 ST165 - project "Rahtid"
'88 ST165 - Project "Supah Cyat"
'91 MR2
GT4_DRED
Postby outinnowhere3193 » Mon Jun 20, 2016 4:19 pm
GT4_DRED wrote:There's quite a bit of grinding needed to clear the transfer case and depending on the year of the block, you may need to tap it for the support bracket to be bolt on. I added a few pics of what I did in my build thread.
Thanks this was the only one I found
viewtopic.php?f=49&t=46304&p=435520&hilit=5s+grind+Transfer#p435520
And the pics wasn't opening...I assume its to old of a thread. Thanks again.
outinnowhere3193
Images: 5
Postby ChrisD » Mon Jun 20, 2016 6:21 pm
Yep what they said, have to grind. I'm getting closer to done on mine. Here's a pic of my grinding:
My build thread: http://www.celicatech.com/forums/showth ... alf/page10
1988 ST165
1994 ST205 WRC
ChrisD
