Hesitating while accelerating
Postby LvX » Thu Aug 04, 2016 6:34 am
Hi All,
i'm restoring my st185 that was sitting in the garage for almost 10 years, after fixing a broken ecu and rewiring the distributor the car now runs fine.
the only problem i'm facing is that the engine does hesitate a bit while accelerating, i don't know how to explain it in english, but if i'm at idle (which is good) and i floor the gas, the car tend to stall and then rev.
If i give it little gas the car doesn't do it.
It seems to me like a lean situation, i've checked the manifold for leak and fixed a few one but nothing changed.
I've also tried to adjust the tps following the bgb without success.
Please help i'm running out of ideas
LvX
Re: Hesitating while accelerating
Postby Q-Ball » Thu Aug 04, 2016 9:25 am
Have you checked the timing?
2007 VW GTI - APR Stage II+, Billyboat 3" Downpipe, APR Upgraded HPFP, Neuspeed Intake
1991 Alltrac - Stock for now
Q-Ball
Postby LvX » Thu Aug 04, 2016 11:11 am
Yes, but will check again tonight
LvX
Postby LvX » Thu Aug 04, 2016 6:14 pm
Double checked ignition timing and tps, it's all perfect now, also found a little leak on the 4th injector, removed and fixed
but still this annoying hesitation :bangshead: :bangshead:
LvX
Postby underscore » Thu Aug 04, 2016 6:57 pm
Have you done a boost leak test?
Postby LvX » Thu Aug 04, 2016 7:08 pm
Yes, this is how i've found the egr was leaking and the 4th injector
LvX
