Slim head gasket for ST185. Stock head and pistons?
Postby ST185l » Sat Feb 18, 2017 3:38 pm
Good afternoon. My question is whether someone has mounted a thinner (slim) head gasket than the original one (3sgte 2 GEN) with the original pistons and the original cylinder head.
How thick? I want to increase the compression ratio, without changing the cylinder head. But I do not know how much distance the valves have with respect to the piston head at its maximum opening
Thank you
ST185l
Re: Slim head gasket for ST185. Stock head and pistons?
Postby T-rilla » Sun Feb 19, 2017 5:14 pm
Not knowing what else you have done to it my recommendation would be a .8mm thick gasket as that is what TRD sold as a replacement for the stock setup. Could also use a cometic(or another brand) 1mm gasket for a slight bump.
From what I have read stock is 1.4mm thick
88 alltrac ST165 ISMA GTO
T-rilla
Postby underscore » Mon Feb 20, 2017 5:21 am
From memory the "TRD" 185 head gasket became the 205 head gasket, so just order one of those. Somewhere on here are pictures detailing the differences.
Users browsing this forum: Google Adsense [Bot] and 3 guests
