It is necessary to mount arp screws to increase boost
Postby ST185l » Sat Apr 22, 2017 9:34 pm
Do you need to mount ARP screws to increase the boost of a Gen 2 or is it not absolutely necessary?
You have to increase the diameter of the block to mount the arp screws? Are they wider than the originals?
Thancks
ST185l
Re: It is necessary to mount arp screws to increase boost
Postby Corey » Sat Apr 22, 2017 10:19 pm
Do you mean ARP head studs?
The factory head gasket on the 2nd gen 3sgte is composite and not metal like the 3rd gen, so with age, a large increase in boost can cause it to fail. I don't think installing ARP head bolts alone will decrease the risk.
If you want to make a difference, I would personally take the cylinder head to a machine shop and have them deck it flat if required. Then reinstall with a metal head gasket and ARP studs.
ARP head studs for the 3sgte are plug and play (no block mods required)
If you don't change anything, I wouldn't risk increasing the boost much more than 10 psi, but there are lots of discussions on this forum regarding this topic.
Corey
Images: 50
