Exhaust manifold leak symptoms
Postby Rallly » Sat Jun 10, 2017 4:15 pm
Can someone tell me what negative things will happen to my performance with my 91 AllTrac 2nd Gen 3SGTE with a pretty bad leak on both ends of my oem exhaust manifold? Sounds like crickets when I punch it! Haha
Rallly
Re: Exhaust manifold leak symptoms
Postby underscore » Sun Jun 11, 2017 7:41 am
It'll hurt your fuel economy, throttle response and power, and the exhaust gases might damage something nearby.
Postby Rallly » Sun Jun 11, 2017 12:11 pm
Is it difficult to remove the manifold? Doesthe turbo need to come off?
Rallly
Postby r-town » Wed Jun 14, 2017 6:38 am
It's a bit difficult if you still have the stock downpipe. After removing the downpipe, the turbo and manifold come out as a single piece.
r-town
Postby Rallly » Wed Jun 14, 2017 8:44 am
I have an after market dp. Isn't there any oil lines going to the turbo I need to remove? Will I need to have gaskets a d o rings on hand to replace them if I take oil lines off?
Rallly
Postby underscore » Wed Jun 14, 2017 3:26 pm
There's a single connection for the oil in/out and a single connection for the water in/out. Replace the gaskets or you'll have headaches in the future.
Postby Rallly » Wed Jun 14, 2017 4:29 pm
Can you send me a pic or part numbers for them plz?
Rallly
Postby r-town » Thu Jun 15, 2017 7:23 pm
r-town
Postby Rallly » Thu Jun 15, 2017 11:59 pm
So I would need the 2 water gaskets and the 2 oil gaskets?
Rallly
Postby r-town » Fri Jun 16, 2017 4:41 am
one of each.
r-town
Postby Rallly » Fri Jun 16, 2017 8:36 am
r-town wrote:one of each.
But the pic shows 3 highlighted? Are you certain I should just buy 1 of each?
Rallly
Postby underscore » Fri Jun 16, 2017 3:35 pm
Yes, there's a plate on the on side of the turbo that has a gasket, but you won't have to remove it to remove the turbo.
Postby Rallly » Fri Jun 16, 2017 6:26 pm
underscore wrote:Yes, there's a plate on the on side of the turbo that has a gasket, but you won't have to remove it to remove the turbo.
So just order 1 of each?
Rallly
Postby Rallly » Fri Jun 30, 2017 9:47 pm
Okay I bought the 2 gaskets, now would it be easier to remove manifold all the way to do all in one peice or take everything off separately? I need to replace the 2 manifold gaskets (manifold to motor) and manifold to turbo. Any suggestions would be appreciated
Rallly
Postby underscore » Fri Jun 30, 2017 10:19 pm
Remove the rad, unbolt the downpipe at the bottom and remove it as an assembly with the turbo and manifold, then disassemble them all on the ground.
Users browsing this forum: Baidu [Spider] and 3 guests
