ST185 to ST185RC intercooler swap?
Postby EvilStig » Sat Jul 29, 2017 12:50 am
I've gotten my hands on an ST185RC intercooler unit and would like to know part numbers and sources I could use to build the rest of the setup (water pump and radiator, primarily) since the OEM ones are not available. Has anyone else done this conversion and knows what parts fit? thanks!
EvilStig
Re: ST185 to ST185RC intercooler swap?
Postby underscore » Sun Jul 30, 2017 1:41 am
You've got the only OEM part required, which is good. I know there are a variety of aftermarket pumps and heat exchangers people have used over the years that are more widely available than OEM, I think some of them are for Mustang Cobras. Do some searching and you should find the info you need.
Postby Celi-GT4 » Mon Jul 31, 2017 1:37 am
My 205 swap came with everything and eventually I upgraded to a bigger pump and heat exchanger. So just do the research and go that way, it will cost less and perform better
12.4 @ 115mph Topeka Kansas NA2005
12.2 @ 109mph blew HG Moroso 1/08
Sold out, now on stock 3rd gen
Blitz ecu, dp,exhaust, tien ss, carbon driveshaft,light wheels/brakes,os giken twin plate
Celi-GT4
Postby EvilStig » Thu Feb 08, 2018 11:15 pm
So I've been searching all over the place but I just can't seem to find any information on alternative parts to OEM on the sub radiator and water pump. Can anyone point me to a build thread with part numbers or tell me what parts they're using in their own WTA intercooler build?
EvilStig
Postby 819_ay » Sun Feb 11, 2018 10:40 am
Just search eBay or even just on Google for WTA heat exchanger, and Bosch water pump... You'd be surprised what Google comes up with...
Sent from my LG-H915 using Tapatalk
819_ay
Postby Maram » Mon Feb 19, 2018 9:05 pm
I got a universal radiator (BIG ONE) and a bosch waterpump.. Works like a charm, partnumber is 0 392 020 031. Universal hoses (?).
https://www.ebay.com/p/New-Bosch-Electr ... 1711176516
Aprox 40 gbp.
I do not have a link to the radiator, but you can look at the pictures and you see how it its.
Imgur link: https://imgur.com/a/XNmAj
1991 Toyota Celica GT4 ST185
2007 BMW 525d 3.0 LCI
Maram
Postby GTSfreak » Mon Feb 19, 2018 11:07 pm
Im considering keeping the setup when i eventually get an alltrac. but a couple people i've talked to claim they did get lower intake temps with an fmic. so im debating on if you can manage the same intake temps of a fmic if you can manage to run a large enough water heat exchange unit to keep it consistent.
GTSfreak
Postby Maram » Tue Feb 20, 2018 6:12 am
GTSfreak wrote:Im considering keeping the setup when i eventually get an alltrac. but a couple people i've talked to claim they did get lower intake temps with an fmic. so im debating on if you can manage the same intake temps of a fmic if you can manage to run a large enough water heat exchange unit to keep it consistent.
Why go for a fmic? They used the w2a intercooler when rallying both the st185 and 205.. If it was good enough for them i guess it is good enough for road use too? 8)
Im using a 205 cooler core, upgraded radiator and bosch waterpump... the intercooler is not hot at all when driving in 25*c.
But its your car and you do what you want to, but if you go for a fmic setup, please do it properly. Many solutions looks like shite imo, the pipes need to be welded together and paintet black/dark grey.
Maram
Users browsing this forum: Google Adsense [Bot] and 2 guests
