CT26 not being able to hold boost?
Postby -==L=a=N=c=E==- » Tue Aug 31, 2004 12:30 am
I know this was mentioned on the old forums, but is it normal for the CT26 to start losing boost after around the 4000rpm mark up until readline?
Reason i ask, i can make 14psi easy, but after a while i lose boost and it drags back down to around 10 psi come redline. At stock boost (wastegate) of 7psi, it'll fade down to around 5-6psi... this is normal right?
-==L=a=N=c=E==-
Postby alltracman78 » Tue Aug 31, 2004 12:55 am
Didn't do that with mine...
In my 93, at ~8psi. Stayed all the way through. :shrug:
Postby -==L=a=N=c=E==- » Tue Aug 31, 2004 1:01 am
thats with the T-vsv pulled and disconnected.
-==L=a=N=c=E==-
Postby Incubusrocks84 » Tue Aug 31, 2004 9:14 pm
Mine boosts like 7-8 all the way up to redline, just feels like there's not much more power past 6000rpm.
on nice and cool nights i get 10psi and i do sometimes see the boost drop a little past 6000.
cheers
'93 GT - Daily beater (miss her dearly)
'92 Alltrac - Weekend warrior, aussie 3" dp and Midpipe,HKS SSQV,HKS EVC,20mm h&R spacers( Miss her more than ever)
'01 Toyota Tacama SR5 V6 TRD
'02 Triumph TT600
Incubusrocks84
Postby -==L=a=N=c=E==- » Wed Sep 01, 2004 1:22 am
Hmmmm.... i have a strange problem then... Any ideas?
Im thinking clogged cat... possibly?
-==L=a=N=c=E==-
Postby Mad1 » Wed Sep 01, 2004 7:50 am
Hi,
I had the same problem when I bought my car, it would boost high in lower rpm range then when it got to higher rpm the boost pressure dropped to half, I found (when I had my clutch changed) that the cat was completly blocked, all the inside had fell to pieces, and I don't know if this had anything to do with it, the original intake pipes between the afm and the turbo had splits in them.
Now they have been changed I can boost at 1.1bar all the time (with boost controller of course)
Darren
1991 JDM GT4
13.799 @ 0m sea level
Image click on me
Mad1
Postby -==L=a=N=c=E==- » Wed Sep 01, 2004 11:31 am
Its exactly what i was thinking, ill get it checked out soon.
Ill double check all my intake clamps again. but i think the cat problem is the winnar.
-==L=a=N=c=E==-
Postby -==L=a=N=c=E==- » Thu Sep 02, 2004 7:29 am
Well i happily would like to report back that i found the problem. I had replaced all the intercooler clamps, and also removed the BOV. My guess is the BOV was leaking under boost. Something so simple huh.
Cheers all for the advice.
-==L=a=N=c=E==-
