intercooler
intercooler
Postby dinorossi » Sat Jul 02, 2005 4:19 am
ok, i never knew that watercooled intercoolers were made until looking at gt4s... is the watercooled intercoolers any better than the normal air cooled intercoolers?
-dean
dinorossi
Postby Fat Trac » Sat Jul 02, 2005 5:14 am
unless you're looking at the 165 intercooler, yeah the wta ones are much better than the stock st-185 a/a.
fmics are just as good if not better, though.
1991 taurus sho. yes, i know, it's a ford.
1990 st-185.
no compression on cyl # 4 = no running alltrac :(
Fat Trac
Postby d1alltrac » Sat Jul 02, 2005 5:47 am
when comparing a stock air to air off a 185 to a stock water to air off say a 185RC, yeah the wta is gonna be better, this is mainly cause with wta it can more effectively prevent/disapate heat soak with the top mount setup (RC prob flows better too though)
but when comparing a/a with wta in general its hard to say which is better, there are aftermarket wta ic's (spearco for example) that can offer flow and pressure drop equal to if not better than your average frount mount
IMO one isnt better than the other, it just depends on your application...a front mount air to air ic is usually best for most but requires more piping which can result in more lag,while a 185RC or 205 wta ic is sufficent for many apps and keeps the shortest path possible
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby Zeus » Sat Jul 02, 2005 6:48 am
yep as pat says its all about application... they both have their advantages and their dissadvantages
typically wta has a shorter intake path and in turn is better for lag... also water is better at disspating heat.... but ata has its advantages as well
Blake Brown
Zeus
Postby toayoztan » Sat Jul 02, 2005 7:28 pm
To slightly add too, the FMIC will be more useful around the highways and such while the wta IC will be more useful for those who do a lot of city driving.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby BraveUlysses » Sat Jul 02, 2005 10:04 pm
Another thing to consider about WTA intercoolers is that if you so desire, you can fill the resevoir with ice and water to obtain intake charges that are cooler than ambient temps, which is flippin awesome.
BraveUlysses
Postby dinorossi » Sat Jul 02, 2005 10:20 pm
............i like the way you think................^^^
would it work to put other things that disate heat faster in it? like radiator fluid, or someother kind of liquid? or would that just be a bad idea?
-dean
dinorossi
Postby jprine01 » Sat Jul 02, 2005 11:18 pm
radiator fluid doesnt disapate heat as good as normal water.. its just helps fight corrosion and provides protection against freezing tempatures.
Waterweter is a additive you can put in water that makes it even better.. and adds corrosion protection.
so it really depends on application again, if your going to be driving in winter your going to need some anti-freeze. If not just use distiled water with waterweter
Or better yet just drain and refil before and after the winter :P
jprine01
Postby beej » Sun Jul 03, 2005 12:00 pm
put alchohol in the system, that dissapates heat far faster than water
and u'll find that a WTA intercooler setup will have ur less effected by changes in weather (ie intake temps)
"ITS A VENT GODDAMIT NOT A F#$KING SCOOP!!!!!"
beej
Postby d1alltrac » Sun Jul 03, 2005 9:04 pm
beej wrote:put alchohol in the system, that dissapates heat far faster than water
thats a good idea
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby jprine01 » Mon Jul 04, 2005 12:23 am
Anyone seen this?
http://www.imoc.co.uk/forums/viewtopic.php?t=10416
I was looking for a st205 chargecooler but this is looking allot better. I like the quick spoolup/short intake path vs. fmic
jprine01
Postby built2run » Mon Jul 04, 2005 2:50 am
i got an idea, if u replace the wta setup with like an ac unit type of thing with colder than ambient air charge, would this be a good option or what? i have been dying to find out.
built2run
Postby jprine01 » Mon Jul 04, 2005 11:33 pm
double post...
jprine01
Postby jprine01 » Mon Jul 04, 2005 11:38 pm
Hrmmm thats a interesting idea, It would take allot of cooling im guessing though. Or even use a a2a or a2w then a A/C system to reduce the strain on the A/C, beause the compresser is going to suck allot of HP.. Dont know how reliable the A/C compresser is to run non stop.
An idea would be using thermal electric coolers (Peltier), with an interesting dual water setup to achive below ambient water temp to a A2W intercooler with just electricity. It would probably take quiet a few amps, if I had a st205 core i might try messing with it. You would need a alternator upgrade for sure... They draw like 20 amps each and i would use a few.
jprine01
Postby d1alltrac » Tue Jul 05, 2005 12:36 am
built2run wrote:i got an idea, if u replace the wta setup with like an ac unit type of thing with colder than ambient air charge, would this be a good option or what? i have been dying to find out.
the supercharged SVT lightning's have something similar to this idea, the supercooler system...here is an explanation:
"Traditional intercoolers dissipate heat from the supercharged air by circulating coolant through a front-mounted, air-cooled radiator. With the SuperCooler system, the vehicle’s air conditioning system is used to chill a small storage tank of coolant to about 30 degrees Fahrenheit. On demand, the SuperCooler system switches the intercooler flow from its normal circulation and dumps the chilled coolant into the engine’s intercooler..."
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
