Differential
Differential
Postby JHem » Thu Sep 02, 2004 8:45 pm
I am looking at a 3sgte swap but i dont feel like doing the AWD swap also, how would the dif out of my tranny with the 1.6 litre engine do if i put that in the 3sgte tranny to keep FWD?
JHem
Postby Plex » Thu Sep 02, 2004 9:35 pm
Just use the 3SGTE tranny.. but block off the output shaft for the rear tires... if you get what I mean.
..:.Red 1988 ST165 All-Trac Turbo.:..
Plex
Postby saved_1992 » Thu Sep 02, 2004 10:02 pm
and why would you think that would work? you can not use the alltrac tranny, no way no how :shoots:
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby CMS-GT4 » Thu Sep 02, 2004 11:20 pm
You can, but there would be less power, and the center diff would burn up in a short amount of time. Just get an mr2 clip, that has the correct gearbox and it has lsd.
Postby JHem » Fri Sep 03, 2004 12:35 am
plex, explain please, and how much is an mr2 clip
JHem
Postby saved_1992 » Fri Sep 03, 2004 12:41 am
ya you can use a alltrac tranny for maybe a week before burns up. again no way no how :shoots:
check out www.celica.net there are alot of swaps and how to
mike
omaha,ne
saved_1992
Postby Plex » Fri Sep 03, 2004 1:04 am
*shrug* is my explanation.
I'd assumed that would work, because isn't that how people make their all tracs into FWD?
Plex
Postby JHem » Fri Sep 03, 2004 1:31 am
isnt the all trac tranny made for...... the all trac motor???
JHem
Postby saved_1992 » Fri Sep 03, 2004 1:49 am
do some research,
the alltrac tranny can be set to fwd for dyno testing with very specific instructions so not to blow up
http://www.celica.net/ check it out
mike
omaha,ne
saved_1992
Postby Plex » Fri Sep 03, 2004 2:02 am
Except for the fact that that site isn't finished and doesn't help.... good call on the research thing tho.
Plex
Postby CMS-GT4 » Fri Sep 03, 2004 3:15 am
First, people do not make their alltracs into fwd cars. The only case of changing drive I have ever heard of was making an alltrac a rwd and dropping in a TT V8.
Next, you can make the alltrac 151 series gearbox go into a FF mode, but it can only be run in 3rd gear or higher, and has to be done for a shirt time to avoid burning up the center viscous lsd.
2nd, the 3sgte (alltrac/mr2 engine) can bolt up to quite a few gearboxes made by toyota. Everything from fwd, awd, and rwd.
3rd, the link that was posted is the source.
Except go here.
http://www.celica.net/cgi-bin/ultimatebb.cgi
The forum has a stickies in the forced induction section that has a complete how-to on using the mr2 gearbox, and making a fwd 3sgte powered celica.
And lastly. Mr2 clips vary, but are around the same cost as a gt4 clip. A few items have to be switched out on the engine, but for the most part, the mr2 would provide a more complete starting point. The only benifit of the gt4 clip is the tmic, and hood, which would not be provided in the mr2 setup.
Postby Plex » Fri Sep 03, 2004 4:31 am
Umm, actually people around here convert theirs to FWD only, to get rid of the drivetrain loss when power is going to the rear wheels.. but whatever.
Plex
Postby Gary » Fri Sep 03, 2004 6:15 am
Plex wrote:Umm, actually people around here convert theirs to FWD only, to get rid of the drivetrain loss when power is going to the rear wheels.. but whatever.
Not that they want to get rid of drivetrain loss, instead, they do FWD only because
1) AWD conversion is not practical.
2) FWD is much easier, they can just use MR2 tranny, Camry tranny, even stock 5sfe tranny.
3) Alltrac tranny will not work, no way no how unless you want to burn the center diff
93 ST185
Gary
Postby saved_1992 » Fri Sep 03, 2004 9:29 am
thank-you (gary & coldiron)
seems to know everything and has had his car since august :lol:
mike
omaha,ne
saved_1992
Postby CMS-GT4 » Fri Sep 03, 2004 1:35 pm
So your claiming people are taking alltracs and making them FWD cars?
If so, I need their names and locations so I can come kick the living crap out of them.
Or do you mean that people do engine swaps and make fwd cars. Which would be using a fwd gearbox, in a fwd car. If so, yeah that happens all the time. Still a bad idea, but it happens.
Users browsing this forum: Yahoo [Bot] and 5 guests
