Shim the wastegate possible?
Postby -==L=a=N=c=E==- » Fri Sep 03, 2004 10:21 am
Well im about to remove this piece of shit in cabin bleed valve and sell it off. Im wondering is it possible to shim the wastegate to achieve more boost?
-==L=a=N=c=E==-
Postby saved_1992 » Fri Sep 03, 2004 10:52 am
yes it is possible but i do not know how much extra boost you will get
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby -==L=a=N=c=E==- » Fri Sep 03, 2004 10:54 am
saved_1992 wrote:yes it is possible but i do not know how much extra boost you will get
Its all trial and error im told... Just needed to know if its been done :)
Ill report back on how it goes :)
-==L=a=N=c=E==-
Postby ___Scott___ » Fri Sep 03, 2004 5:29 pm
I've done it, but I recommend just going with a ball/spring boost controller. You can build your own or pick one up cheap off eBay. I made mine and it works great.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Griffin » Fri Sep 03, 2004 8:02 pm
Yup it works - mine has 3 washers stacked between the wastegate actuator and compressor housing at both bolts and I made about 24 PSI with the factory controller at 100% duty cycle. I think theres actually more boost left in it still, but I'm looking for an electronically adjustable means of proper control. I've been considering trying to add a restrictor in the line from the compressor to the actuator
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby -==L=a=N=c=E==- » Fri Sep 03, 2004 8:23 pm
3 washers and 24psi! f*** me! Ill try 2 washers, and see what i get... Im only aiming for around 1Bar MAX.
-==L=a=N=c=E==-
Postby st185-sainz » Sat Sep 04, 2004 1:02 pm
I normally use M10 nuts for shiming! this works fine and I normally get 1-1,1bar boost!
Mario,
ST205 blue: completely stock
ST185CS (white): white - gravel/snow spec, dog box, TRD clutch, uprated turbo, lightened flywheel, uprated actuator, cold air intake, ST182 cams, walbro pump, batt relocation, forgies, programmable ECU (dyno), ...
st185-sainz
Postby Griffin » Sun Sep 05, 2004 9:12 am
I should add that I have a modified CT26 not a stock one - your results may vary.
Dave Staba
Sealy, TX
Griffin
Postby facapino » Mon Sep 06, 2004 2:33 am
can anyone post pics on exactly where to put the washers? sorry for the ignorance. :oops:
or at least a detailed explanation.
thanks
facapino
Postby -==L=a=N=c=E==- » Mon Sep 06, 2004 12:01 pm
facapino wrote:can anyone post pics on exactly where to put the washers? sorry for the ignorance. :oops:
thanks
Ill take some pictures for you when i do mine (wednesday hopefully)
Basically, on the compressor housing, there is a bracket which holds the wastegate actuator. It is held on by 2 screws. By putting washers inbetween the bracket and the housing, you can increase the boost, as the actuatot is further away from the wastegate, therefore more boost.
-==L=a=N=c=E==-
Postby facapino » Tue Sep 07, 2004 3:45 am
ok thanks. though i got the basic idea. :)
facapino
Postby superalltrac » Wed Sep 15, 2004 1:36 am
I've shimmed my wastegate and I got about 5 extra psi. before I shimmed I believe I was only getting 3 psi. I have also since put in a MBC and now I finally get 12 psi. I think it's time to rebuild the turbo or get a new one. Does anyone have a used one for sale?
Trevor,
1988 ST165 (ST185 turbo)
283,000 kms and still going
(well somewhat, haha)
superalltrac
