headgasket
headgasket
Postby toyotaluver » Fri Sep 03, 2004 6:57 pm
what causes a headgasket to blow? just wondering thanks.
1991 Toyota Celica Alltrac
Upgraded CT-26
Apex'i intake
3in exhaust from downpipe
Autometer boost and a/f gauge
3 gauge pillar pod
HKS ssbov
custom front mount intercooler
toyotaluver
Postby RIalltrac » Fri Sep 03, 2004 7:00 pm
i'm gonna take a whack at things like overheating, over pressurizing (too much boost) and just the general age of the gasket. I'm sure there are other reasons as well.
Chris - 90 ST185
RIalltrac
Images: 2
Postby Gary » Fri Sep 03, 2004 8:10 pm
Detonation
93 ST185
Gary
Postby ___Scott___ » Sat Sep 04, 2004 4:32 am
I agree with Gary, Detonation is #1 cause. Overheating also possible but I suspect much less common.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby turbo4wd » Sat Sep 04, 2004 5:45 am
___Scott___ wrote:I agree with Gary, Detonation is #1 cause. Overheating also possible but I suspect much less common.
Actually.. on stock cars, of any make or model it is much more common for a head gasket to fail due to an extreme overheat.. Detonation isn't going to come into the picture until you've got some mods going.. In other words, provided everything is running properly and until you're exceeding the capabilities of the stock fuel map, you shouldn't have any "serious" concerns with detonation..
If you really want to get technical.. Detonation can kill the head gasket itself.. whereas an extreme overheat will warp the head or block which compromises the head gasket's ability to create a proper seal which then leads to coolant leaking into the combustion chambers and from there you've just got a bigger can of worms waiting..
In both cases the seal is broken.. and thats just not cool.. :doh:
Dan
Undercover Moderator
turbo4wd
Postby Stubble » Mon Sep 06, 2004 11:37 pm
Somebody on the board had a list on their own website about "How to blow up your motor", and it was based on peoples' experiences. I think it would help this conversation, but I've lost the link. Anyone know where it is?
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Heat vs detonation ?
Postby GMan » Tue Sep 07, 2004 2:44 am
Detonation can happen on a stock car.
It is all interrealted.
If the car over heats, is it more prone to detoantion ? :-)
Of course the head gasket will blow if you run out of coolant or something...
Of course if you are racing and keep boosting
as the temps rise, then it is all bad.
Regards;
GMan
Re: Heat vs detonation ?
Postby turbo4wd » Tue Sep 07, 2004 10:40 pm
GMan wrote:Detonation can happen on a stock car.
Regards;
I meant detonation occuring by itself, due to a lean condition.. not as a byproduct of an overheating engine.. But yeah.. both suck :P
Dan
turbo4wd
Postby Plex » Tue Sep 07, 2004 11:28 pm
Also not torqueing the head studs in the right order, or at the wrong ft/lbs
..:.Red 1988 ST165 All-Trac Turbo.:..
Plex
