sparkplugs???
sparkplugs???
Postby 3SGTEWRC » Mon Sep 06, 2004 5:47 am
what sparkplug is best for the 3sgte??? and the heat range???
COROLLA HB + 3SGTE = 3SGTEWRC
3SGTEWRC
Postby alltracman78 » Mon Sep 06, 2004 10:43 am
NGK(better) or Denso
Don't have part # right now.
Heat range depends on what you've done to your car.
Postby Dickie » Mon Sep 06, 2004 12:43 pm
Check out this links:
http://www.ngksparkplugs.com/apps/
http://www.ngksparkplugs.com/apps/car_t ... esults.asp
1990 TOYOTA CELICA ALL TRAC 2.0 L4 3S-GTE EFI TURBO
Spark Plug Part No. Stock No. Plug Gap
Standard BKR6ES 3783 .032
V-Power BKR6E 6962 .032
G-Power Platinum BKR6EGP 7092 .032
Laser Platinum BKR6EP-8 * # 2215 . 032
Iridium IX BKR6EIX 6418 .032
GT-FOUR_JDM / Alltrac RULES!
Dickie
Postby AWDios » Mon Sep 06, 2004 4:48 pm
Talk to Robert (the admin) He was going to run some special deals on bulk buying the NGK's in one range colder.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby CodingParadox » Mon Sep 06, 2004 4:58 pm
You're not supposed to touch the NGK Iridiums' gap, right? Jeremy told me that I just want to stick them in as they come, because if you try to gap them, it'll break the iridim electrode.
CodingParadox
Postby 1stGenAllTrac » Mon Sep 06, 2004 7:36 pm
no u cant gap iridium plugs. but they're a waste of money in my opinion anyways, i had em on my car for a while. ran like a bag of poop once the temp dropped below about 40 degrees.
copper plugs give best bang for buck, more conductive than pretty much anything just u gotta replace em more often. I'm replacing mine at next oil change, every 6months i throw a new set of NGK's in. dont hvae the part # handy tho.
1988 st-165 :: not stock....
1stGenAllTrac
Postby RedCelicaTRD » Mon Sep 06, 2004 8:35 pm
Im pretty sure you can gap them but you have to be really careful. I'd just get the copper ones though, they work better but dont last as long.
Postby CodingParadox » Mon Sep 06, 2004 9:50 pm
Meh, pacific northwest, it like never drops below 40 here anyway. :)
CodingParadox
Postby jlcelica » Mon Sep 06, 2004 10:06 pm
I'm using ngk 6097 copper spark plugs that are one step colder than stock .
jlcelica
correct temp range
Postby GMan » Tue Sep 07, 2004 2:51 am
>1stGenAllTrac
>Posted: Mon Sep 06, 2004 7:36 pm
How much boost are you running ?
What was the heat range of the iridiums you put in ?
You really only need a colder plug if you are
running BOOST. :-)
> Location: ontario, canada eh
Well there you go ! If the plugs or the temp was too cold,
the car will run like poop. :-)
The THIN Iridium tips foul easier than the wider copper.
Plus the Cold start injector dumps a lot of fuel to
richen the mixture on cold days. U Might need a
Hotter plug in COLD days ?
I 2nd that. Cheap copper work better IMHO, and
you can switch them for summer, winter... :-)
Yah, that can be a PITA.
Regards;
GMan
Postby pepper » Tue Sep 07, 2004 3:50 am
CodingParadox wrote:Meh, pacific northwest, it like never drops below 40 here anyway. :)
Sure seems that way sometimes LOL! Although last winter my house looked like this for a week, not too common for Portland:
Anyway, I agree that copper seems to be the best although I'm still using platinum on mine, until I use up the sets I had on hand. And, yes, one heat range colder.
-Mike
Mike
'88 ST165
Vancouver, WA USA ------------------------------ mine
pepper
