st205 into st185 swap faq/ and parts compatibility
Re: st205 into st185 swap faq/ and parts compatibility
Postby CMS-GT4 » Wed Mar 05, 2014 2:53 pm
Yes. 90-91 and 92-93 are different.
Postby essexgt4 » Wed Mar 12, 2014 6:36 am
Ok couple of questions as we are nearly there, which sensors did people use from the 205? For example boost sensors map sensors, temp sensors etc?
essexgt4
Postby phattyduck » Wed Mar 12, 2014 5:00 pm
essexgt4 wrote:Ok couple of questions as we are nearly there, which sensors did people use from the 205? For example boost sensors map sensors, temp sensors etc?
If you are using the ST205 ECU, you will need to use the MAP sensor at a minimum. Why not use everything that comes with the motor?
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby soarer.jzz30 » Thu Mar 13, 2014 10:59 pm
https://drive.google.com/file/d/0Bx7oVW ... sp=sharing
this is everything i have on both cars
https://drive.google.com/folderview?id= ... sp=sharing
i will make a separate post for help with this. i made the file based on another photo, i need help finishing it for help with my own swap and anyone else planning it. i put a place for standard voltage and resistance and the circumstance that it requires to test. I would like to add if it is an input ir output or ground next to it as side notes, as of now it is two page printable. anything else added will be to large but that's ok. i am doing this because my swap is still not starting so this should help point in the right direction, thanks to anyone with a working gen3 swap in an st185. :D
soarer.jzz30
Postby essexgt4 » Tue Mar 18, 2014 8:12 am
Out of curiosity which do you think would be easier to use, I have a 1993 st185 car with loom, rev 3 engine turbo gearbox etc already installed now i have a choice on ecu, import mr2 turbo rev 3 ecu or uk spec st205 ecu?
essexgt4
Postby fhalperformance » Mon Mar 24, 2014 12:48 am
-ST205 axle, ST185 axle, ST205 axle, ST185 axle lined up fairly closly on the inboard splined sections.
Difference between st205 axles and st185 axles finally documented. Its a good 2 inch difference in length give or take.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby soarer.jzz30 » Mon Mar 24, 2014 10:02 am
Much appreciated fhal. Huge track width difference.
soarer.jzz30
Postby fhalperformance » Fri Mar 28, 2014 11:30 pm
It drove me crazy that everyone said they were too long and there was no photographic evidence. I was going to do a write up using a 3rd gen mr2 ecu so I could go front mount intercooler without having to do any wiring modifications until I saw this 600awhp trac with a wta top mount https://www.youtube.com/watch?v=h_Os-ayIgaE
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby phattyduck » Tue Apr 01, 2014 6:06 pm
fhalperformance wrote:It drove me crazy that everyone said they were too long and there was no photographic evidence.
You can just look at the factory rated track width between the 5th and 6th gen Celicas to know that they won't work... (rears are 1.2"/30mm longer for each axle - that's the one I have measured and looked up) The real kicker is that they are 1-piece, with means you can't mix-n-match or do hybrid setups with parts that can be rebuilt in the US.
phattyduck
Postby soarer.jzz30 » Tue Apr 01, 2014 6:20 pm
Can't we just do a whole rear end swap though
soarer.jzz30
Postby phattyduck » Tue Apr 01, 2014 6:31 pm
soarer.jzz30 wrote:Can't we just do a whole rear end swap though
Of course (I have). You need the axles and arms to match lengths and that's it. The rear end will then look like you put 30mm spacers on each side, but you don't load the wheel bearings wrong or anything.
You just can't swap the front axles unless you do custom long a-arms.
phattyduck
Postby CTechBlueDragon » Tue Apr 01, 2014 6:41 pm
I also noticed the difference... so is this going to be a problem with the front control arm mount? It should be offset with the 205 rear stuff installed... I am planning to use all the 205 stuff sans the knuckles because they were non abs.
So I wont need my 25mm spacers in the back at all after this is together?
CTechBlueDragon
Images: 50
Postby phattyduck » Wed Apr 02, 2014 6:42 pm
CTechBlueDragon wrote:I also noticed the difference... so is this going to be a problem with the front control arm mount? It should be offset with the 205 rear stuff installed... I am planning to use all the 205 stuff sans the knuckles because they were non abs.
If you currently have 25mm spacers on the rear, doing the full 205 rear swap will push each wheel out another 5mm (like having 30mm spacers with ST185/ST165 rear arms/axles). It should drive the same, other than adding the LSD (assuming you are getting the Torsen diff too). You will need to get an alignment and camber bolts too...
phattyduck
Postby CTechBlueDragon » Wed Apr 02, 2014 9:49 pm
Yeah.... I have a set of camber bolts but they don't fit the back only the front =( boooo I guess I can sell the spacers and get what I need.
I got the diff that came with the 205 are there different ones?? I heard the LSD makes a big difference in how the car behaves cornering, maybe pushing slightly less and rotating more?
CTechBlueDragon
Images: 50
Postby phattyduck » Thu Apr 03, 2014 4:16 pm
CTechBlueDragon wrote:I got the diff that came with the 205 are there different ones?? I heard the LSD makes a big difference in how the car behaves cornering, maybe pushing slightly less and rotating more?
All ST205s came with the LSD rear diff. It was optional on the ST185 (though rare) and the ST165 was always an open rear diff.
You'll feel the difference on corner exit under power. It shouldn't make any difference under braking or maintaining speed through a corner apex.
phattyduck
