st205 into st185 swap faq/ and parts compatibility
Re: st205 into st185 swap faq/ and parts compatibility
Postby soarer.jzz30 » Fri Apr 04, 2014 9:24 pm
Has anyone addressed fact that there is a temp switch sensor in the 185 water neck that is not present in the 205 and is an inline switch for the a/c condensor fan.
soarer.jzz30
Postby CMS-GT4 » Fri Apr 04, 2014 10:41 pm
Yep I brought it up in the ac swap thread. I plan on exploring it once I get time.
Postby soarer.jzz30 » Sat Apr 05, 2014 1:40 am
Ill check my schematics as well. I still have sensor
soarer.jzz30
Postby CTechBlueDragon » Sun Apr 06, 2014 1:06 am
Well... I got all the wires going to the chassis labeled just by looking at the fuse box lid. I have a Chilton that has full wiring diagrams for the chassis and ecu so now I just have to read my book and connect those wires to the right ones on the fuse box. Pretty simple really. I went a little crazy and removed and unwrapped the entire front chassis harness and I am going to do a wire tuck and removing all the wiring for the ABS and AC systems leaves very few wires to figure out. This allows you to remove both of those relay boxes on the passenger side near the abs/ugly nasty dust grease collector brick. I think about the only thing I have to figure out on the engine harness is I think I need to scavenge the entire wiring for the cruise control and put it into the 205 harness... I do want to get that working as well. I am getting to the point with the wiring I am starting to memorize it and the wiring diagrams are making so much more sense to me! lol I am all self taught so don't laugh.
CTechBlueDragon
Images: 50
Postby fhalperformance » Mon Apr 07, 2014 9:46 pm
Anyone have a picture of the map sensor & where its located on the harness from the st205. I seem to have misplaced mine or just cant see it anymore because it dropped down somewhere.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby quieter » Tue Apr 08, 2014 3:20 pm
talkinb about the map sensor... do st205 engine clips come with them? if not then i guess i need to buy one?
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby soarer.jzz30 » Tue Apr 08, 2014 4:11 pm
It's located to the right side of the strut bar just off center underneath it closer to the firewall. Should have a purple and silver sticker, three wires : red, brown, blue/red. Being, pim e2, and volt +5 that also ties to the tps
soarer.jzz30
Postby fhalperformance » Tue Apr 08, 2014 9:07 pm
The only sensor I have thats purple and silver is left of the intake manifold passenger side and says turbo press or sensor on it. Red, brown, grey-black. Only wires I have disconnected are 2 pin plugs x2. I don't know where my ac idle up is could it be with that sharing a bracket?
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby phattyduck » Wed Apr 09, 2014 4:41 pm
fhalperformance wrote:The only sensor I have thats purple and silver is left of the intake manifold passenger side and says turbo press or sensor on it. Red, brown, grey-black. Only wires I have disconnected are 2 pin plugs x2. I don't know where my ac idle up is could it be with that sharing a bracket?
That's the MAP sensor.
MAP sensor is up on the firewall, near the wiper motor. AC idle-up is near where the igniter/coil mounts, just towards the middle of the car.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby fhalperformance » Wed Apr 09, 2014 11:00 pm
Here I was thinking they were separate sensors. Thanks for your help.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby soarer.jzz30 » Thu Apr 10, 2014 5:18 am
My a/c idle up is right next to the wire harness inlet into the interior. Same place as yours up there but the 185 wiper motor is on the drivers side. It should have two vacuum lines off it running the firewall
soarer.jzz30
Postby fhalperformance » Thu Apr 10, 2014 3:18 pm
got a picture of the connector for the A/C idle up? Is it a two pin black plug? That's the only connector I have unaccounted for at this point.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby soarer.jzz30 » Thu Apr 10, 2014 5:27 pm
Might be easier if you take a pic of the two connectors youre talking about
soarer.jzz30
Postby fhalperformance » Fri Apr 11, 2014 2:07 am
Would like connector identification of these:
picture 1: 3 plugs near ECU plugs
picture 2: 2 pin plug near coil/evap solenoid plug
picture 3: white connector "inside car" on engine harness
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby soarer.jzz30 » Fri Apr 11, 2014 3:05 am
Do you have a pic with the wires on the other side as well
The first set of three are the ecu plugs. If the white plug has lots of brown wires and two exposed ones that lead to the knock sensor and the dizzy shielding its the main ground junction
soarer.jzz30
