manual boost controller or not, that is the question
Postby AWD_MOFO » Tue Sep 07, 2004 6:39 pm
So i've been eyeing this Dual stage MBC from Turbo-sx for a while know and i wana know some feed back from people who own/owned a MBC. This particular MBC has two boost controllers connected to each other and with a flip of a switch can open the second one set at whatever psi you choose. I'm thinking, great, it's compact, and i can go from a daily 8psi to like 12-14 psi in an instant in case some honda nerd thinks his turbo running -2 psi is cool . Hit me back with the good and the bad on this MBC. thanks!
The younger brothers time has come...
AWD_MOFO
Postby alltracman78 » Tue Sep 07, 2004 10:45 pm
Never used this particular mbc, but I would reccomend one. Even if set at fact boost, it will make your boost raise up quicker.
don't know about the 2 stage :| You only really need one boost level (Unless you have 2 different fuel maps, and one is for race gas, in that case you can run higher boost, but only with those maps), so this might be overkill. I spent $21 on mine, and it works fine.
If you don't want to hit a higher boost, relax your foot. :wink:
Postby BoostJunkee » Thu Sep 09, 2004 2:31 am
The only advice I can offer on MBC's is be careful with them. They are pretty well known for boost spikes.
Commonly they will spike up 2-4psi over where its set, then settle down to where it is supposed to be.
Stupid Honda - 13.6@100mph
BoostJunkee
Postby SLC Punk » Fri Sep 17, 2004 11:20 am
I built my MBC (only 1 setting) and I have never had any boost spikes or boost creep. I used the procedures from a DSM board, but used a dual ball and spring setup instead of the single ball and spring that the instructions used.
I run 10.5 and have found that to be a happy medium. 8)
-Travis
1992 ST185
2014 4Runner Trail
2015 Lexus GX460
1978 F250
SLC Punk
Postby BoostJunkee » Fri Sep 17, 2004 12:25 pm
SLC Punk wrote:I built my MBC (only 1 setting) and I have never had any boost spikes or boost creep. I used the procedures from a DSM board, but used a dual ball and spring setup instead of the single ball and spring that the instructions used.
link those instructions please :)
BoostJunkee
Postby Zeus » Fri Sep 17, 2004 4:47 pm
i praise mbc's for being cheap boost control... BUILD YOUR OWN!!! they are just as good
however if your getting more serious as far as larger turbos ect... def dont cheap out... but if your just looking for some more fun on a basically otherwise stock car... do it up for sure... just watch the boost gauges... espesially on cold nights... as mbc's are very weather dependant
Blake Brown
Zeus
Postby SLC Punk » Fri Sep 17, 2004 5:37 pm
Here you go.
http://www.geocities.com/chmwatson/FAQs/mbc.html
8)
-Travis
1992 ST185
2014 4Runner Trail
2015 Lexus GX460
1978 F250
SLC Punk
