im scared and need some tipe of answer
Postby 3SGTEWRC » Wed Sep 08, 2004 1:07 am
last night i removed the o2 sensor (the one located in the factory cat) an the sensor is white is this normal? that does it mean? whould i be scared :shrug: ?
COROLLA HB + 3SGTE = 3SGTEWRC
3SGTEWRC
Postby turbo4wd » Wed Sep 08, 2004 1:18 am
just replace it.. 8)
Dan
Undercover Moderator
turbo4wd
Postby Griffin » Wed Sep 08, 2004 3:54 pm
yeah its normal if you live in Cali - something they put in the gas causes white deposits in the exhaust - probably unrefined sulphur.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby edv-tek » Thu Sep 09, 2004 10:55 pm
Say is it true that you guys out in Cali have to live with 91 octane. Say it isn't so :cry: .
Ed Vaughan
White Supercharged Previa LE Alltrac w/beige leather 208K and counting
1988 Mercedes Benz 560SL 42K
Maryland
edv-tek
Postby Griffin » Thu Sep 09, 2004 11:06 pm
edv-tek wrote:Say is it true that you guys out in Cali have to live with 91 octane. Say it isn't so :cry: .
Yup state regulation. Mind you you can still go and get 100 or 103 at the race shop, but we basically have to run the 91 horse piss for day to day use.
Dave Staba
Sealy, TX
Griffin
Postby busdriver » Fri Sep 10, 2004 4:39 am
I have the same stuff here in MT, you get to choose between 85.5, 88, and 91. Yay! Lucky us!! :x
Jake
90 st185
needs tlc
busdriver
Postby Rick89GTS » Fri Sep 10, 2004 6:08 am
Here in BC, Canada, we have up to 94 octane but it's fuckin' expensive, averaging about C$3.60 or US$2.75 per gallon :shoots:
Rick89GTS
Postby edv-tek » Mon Sep 13, 2004 7:45 pm
94 octane for about $2/gallon or 100 unleaded for $4.20/gallon 'round here
edv-tek
Postby gearhead313 » Mon Sep 13, 2004 8:16 pm
white deposits can sometimes mean some coolant going through the exhaust.....not good
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby MrWOT » Tue Sep 14, 2004 2:40 am
If it was coolant the ECU would throw a code. Getting either coolant or any kind of silicate on an O2 sensor will ruin it instantly. If you want to test that, get an old O2 sensor, clamp it in a vice with a voltmeter attatched, then heat it up with a blow torch and test it (normal readings are 0.1V - 0.8V), then spray it with coolant/or coolant smoke, it will either put way WAY lower voltages (0.07 or lower) or will stop completely. This is one reason you never want to use silicate adhesives on your manifold or head gasket, even the slightest ammount will cost you an O2 sensor if it gets in the intake exhaust tract :D
(edit sp)
MrWOT
Postby Indy3sgte » Tue Sep 14, 2004 8:48 pm
okay mine is white too :cry: where do I get a new one? Am I okay if no code is being thrown?
Thanks
Dan
Indianapolis, IN
1990 ST185
Rebuild Pictures (UPDATED!! AGAIN!)
Indy3sgte
Postby alltracman78 » Tue Sep 14, 2004 10:15 pm
you are proably good. Depending on mileage, won't hurt to replace. You can get at dealership (best) or go to auto store, get 4 wire, and wire into yours.
Postby gearhead313 » Wed Sep 15, 2004 12:47 pm
MrWOT wrote:If it was coolant the ECU would throw a code. Getting either coolant or any kind of silicate on an O2 sensor will ruin it instantly. If you want to test that, get an old O2 sensor, clamp it in a vice with a voltmeter attatched, then heat it up with a blow torch and test it (normal readings are 0.1V - 0.8V), then spray it with coolant/or coolant smoke, it will either put way WAY lower voltages (0.07 or lower) or will stop completely. This is one reason you never want to use silicate adhesives on your manifold or head gasket, even the slightest ammount will cost you an O2 sensor if it gets in the intake exhaust tract :D
(edit sp)
i'd agree if it started dumping coolant through the motor, but i've had ones where water would just start seeping out from somewhere, not causing total meltdown, but enough to lean it out and cause this condition.
.....or, boost makes heat. could be just from the lil bugger getting hot from high egt's.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby Indy3sgte » Sat Sep 18, 2004 1:28 pm
Should I test mine this way? where I put the voltmeter?
Thanks
Dan
Indianapolis, IN
1990 ST185
Indy3sgte
Users browsing this forum: Google [Bot] and 4 guests
