goal is 240-260 whp or close
Postby 190hpcelica » Fri Sep 10, 2004 3:40 am
hi guys, i want to know what do i need to make 240-260whps from the 1st gen. what i have in mind is rebuild eng. upgrade to a 50trim, full exhaust system, including the dp. and intercool air to air. and touch up with a boost controller. thanks gary (still like the old forum better) :D
st 165 northern new jersey
190hpcelica
Postby CelicaGT4 » Fri Sep 10, 2004 6:31 am
you're gonna have to do a whole lot more than that. Might want to consider motor swap instead of rebuild. Maybe 2nd gen 3sgte or even 3rd gen? Should be fun though.
Www.gemstatepestsolutions.com
CelicaGT4
Postby RIalltrac » Fri Sep 10, 2004 1:55 pm
its all about the fuel, gotta get that all straightened out before you can start putting down any serious power. Check out http://www.mrcontrols.com/, granted its geared towards mr2's but its still the same engine.
Chris - 90 ST185
RIalltrac
Images: 2
Postby AWDios » Fri Sep 10, 2004 1:59 pm
I'm betting on a stock motor, with an EMS, you could get close.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby alltracman78 » Fri Sep 10, 2004 2:35 pm
CelicaGT4 wrote:you're gonna have to do a whole lot more than that. Might want to consider motor swap instead of rebuild. Maybe 2nd gen 3sgte or even 3rd gen? Should be fun though.
Shouldn't be that hard on a 1st gen, especially if you've got a turbo/intercooler upgrade.
EMS would help quite a bit too.
Re: goal is 240-260 whp or close
Postby turbo4wd » Fri Sep 10, 2004 4:12 pm
190hpcelica wrote: rebuild eng. upgrade to a 50trim, full exhaust system, including the dp. and intercool air to air. and touch up with a boost controller.
You'll be close with these.. add a EMS, and you'll easily hit 260..
Dan
Undercover Moderator
turbo4wd
Postby 190hpcelica » Fri Sep 10, 2004 4:58 pm
the thing is that i dont want to do a motor swap. im not sure if its worth doing the ct26 modded. one or just buy the one from 935 motor sport
190hpcelica
Postby alltracman78 » Fri Sep 10, 2004 5:17 pm
You can easily hit 260 with the stock engine, with some mods. The basic engine isn't much worse than a 185/205.
Postby billprice » Fri Sep 10, 2004 6:43 pm
Did someone not read that he wants 240-260 WHEEL horsepower? To get 240 at the wheels, you would need almost 290 at the crank. I think the stock injectors are 440? Those would be barely good for 260 at the crank. You would have to increase your fuel rail pressure 10 psi to flow enough for 290 crank horsepower. So that means you would also have to add an adjustable fuel pressure regulator into the mix. And I would forget about rebuilding the engine unless you just want to. I don't think you would need to go to that extreme if your engine is healthy.
'07 GS350 AWD
'09 Toro Z5030 ZTR 23hp of lawnmowing fun
billprice
Postby CelicaGT4 » Fri Sep 10, 2004 7:28 pm
The truth hurts like a son of a bitch.
CelicaGT4
Postby ChrisD » Fri Sep 10, 2004 8:31 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby 190hpcelica » Sat Sep 11, 2004 12:11 am
well... i just want to make the car run mid to low 13s. i figure that if i get 240-260whp than itll b around there or close to it
190hpcelica
Postby Trance4c » Sat Sep 11, 2004 3:55 am
190hpcelica wrote:well... i just want to make the car run mid to low 13s. i figure that if i get 240-260whp than itll b around there or close to it
lose weight
Trance4c
Postby Kyoto » Tue Sep 14, 2004 11:02 am
Ha! I got that exact setup on a 165 engine. I haven't put some of the bits on though. At the minute its pushing about 240 at the fly but i haven't put on the CT20b/MHG/FPR/Lightened flywheel/FMIC yet.
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
