Fuel rail options?
Fuel rail options?
Postby alltrac4life » Fri Sep 10, 2004 4:52 am
I have supra tt 540cc injectors and i got a good look at my stock fuel rail and decided that it is pretty crappy in the flow department. I am in the midst of a rebuild and would like to get a different fuel rail. I dont know who makes a better stock replacement fuel rail. What options are there for me?
AEM EMS,JE PISTONS,4 ANGLE VALVE JOB,PORTED HEAD,PORTED MANI.,EXAUST OF TURBO,57TRIM CT26,HKS 264 CAMS,SPRINGS,RETAINERS,3IN. EXAUST,CUSTOM INTAKE,MSD IGN.,SX FUEL REG. WOLFKATZ FUEL RAIL,550 INJ.,ACT 6-PUCK CLUTCH,HKS HG,FIDANZA FLYWHEEL
alltrac4life
Postby pog0 » Fri Sep 10, 2004 8:06 am
Have you considered boring out your rail a bit and making it dual feed? Heard this and removing the banjo bolts and converting to AN fittings helps the flow.
Otherwise you could possibly try LB's top feed billet fuel rail, dont know how long it will take to get to you though.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby alltrac4life » Fri Sep 10, 2004 1:49 pm
well i want to use the supra injectors i got, because i had them cleaned and flow tested by RC and now they are in tip top shape. So i need a side feed fuel rail.
alltrac4life
Postby billprice » Fri Sep 10, 2004 6:27 pm
I assume you have a ST165? The Supra TT injectors are drop in for the ST185 rail.
'07 GS350 AWD
'09 Toro Z5030 ZTR 23hp of lawnmowing fun
billprice
Postby alltrac4life » Fri Sep 10, 2004 11:06 pm
no i have a st185. I just want a higher flowing fuel rail.
alltrac4life
Postby billprice » Fri Sep 10, 2004 11:50 pm
Well now I am really confused. Do you think the stock fuel rail will restrict the Supra injectors? I am running 750 cc injectors with the stock rail and am thinking about going to 1,000 cc injectors.
'07 GS350 AWD
billprice
Postby alltrac4life » Sat Sep 11, 2004 12:50 am
The fuel rail looks a bit restrictive, thats all.
alltrac4life
Postby billprice » Sat Sep 11, 2004 3:45 pm
If you get rid of the banjo fittings and go to AN fittings, you will have no problems there at all. In my present state of tune I am making 379 wheel horsepower with 750 injectors, and, as I said before, am thinking of going to 1,000 injectors because I have a bigger turbo now. Flow should not be an issue at all.
'07 GS350 AWD
billprice
Postby pog0 » Sun Sep 12, 2004 2:18 am
Bill,
I strongly suggest you run a bigger rail. The stock rail can only flow so much even if the banjo bolts are gone and it is dual feed. My honest opinion is to get a bigger rail, and stick with your 720s.
You are dynoing to 2 wheels right? I've seen MR2s push 400 rwhp with 550s and the stock rail bored out. I am pretty sure 720s will get you pretty far.
Kevin Hall
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby WolfKatz » Mon Sep 13, 2004 4:23 pm
Hello all,
I have a pretty interesting post running on the MR2 Board about this right now. I can re-post all of the info. here if you would like. For now, please look at:
http://www.mr2oc.com/showthread.php?s=&threadid=51944
Cheers,
Garrett
WolfKatz
Postby Griffin » Mon Sep 13, 2004 4:43 pm
WolfKatz wrote:Hello all,
Cheers,
Garrett
Neat stuff - how much are the rails and how does one go about obtaining one?
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby WolfKatz » Mon Sep 13, 2004 5:40 pm
To find out about the rails, go to
www.wolfkatz.com
I am in still looking for my first All-Trac sale, but I have inspected one of your rides and I am convinced it will work without any problems.
Cheers,
Garrett
WolfKatz
Postby gearhead313 » Mon Sep 13, 2004 8:39 pm
I was on that 1000cc kick back in the day, and honestly the fastest you'll go on the street you wont need more fuel than a 750cc injector can fire.
Also, dont forget about pressure. Most cars i've had did not have enough pressure to push the fuel through the injector before there wasn't enough fuel volume.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby Celi-GT4 » Tue Sep 14, 2004 1:06 am
Bill your rail is fine to 430whp. I have hit this with 850ccside feeds and a ATS bored rail and with stock fittings. Could go higher if ingnition allowed.
On another note I don' think you can push 550 beyond 340-350 whp. 400whp is crazy power and the supra inj cannot phiscally flow enough fuel (maybe for 1 dyno pull:)
Celi-GT4
