JDM folding Mirrors
Any country, GT-Four for sale or parts
Re: JDM folding Mirrors
Postby Droptop93 » Fri Jan 15, 2010 1:40 am
The glas shape is the same *
Check the uk ebay. The non power folding mirrors there are lhd you can get them and take the mirror part out and put them in the power folding ones you have.
Droptop93
Postby DeeCee » Mon Jan 18, 2010 2:25 am
RedCelicaTRD wrote:I'm looking for a new control unit and passenger mirror, are you willing to seperate?
Sorry, not willing to seperate.
DeeCee
Postby DeeCee » Mon Jan 18, 2010 2:57 am
Okay folks, I have tested out the units and have decided on final pricing.
$100 per set ex shipping and as I can't be bothered priming etc, I am removing that option availability. I am assuming that most people will be able to sand and prime to the colour of their own car.
What you get:
1x LH Folding mirror
1x RH Folding mirror
1x Mirror Control Module
1x Switch
All wired up in working order, ready to apply positive and negative for your own testing at home. It is the purchaser job to extend wiring as required. I recommend a 15A fuse on the power.
This is the list of people who will be offered the sets as in order of contact:
sheikhas
MixMaster
minus alltracshoak and AvivB who pulled out.
PM's coming your way soon with freight estimate as well. Paypal accepted unless you want to use credit card which will incur a 3% surcharge.
As you can see, I did a little work to get everything up and running. I used this thread to establish the wiring: Link
I also found out that the there are no differences between the mirror control relay modules 87989-20020 and 87989-20030. Both work the same as shown in the video.
Set A: More weathered paint of the two sets, but does come with mirror heater wiring. I only know that white/black stripe is ground, so its up to the purchaser to figure out the heated mirrors wiring. Uses 87989-20030 module.
Set B: I had a spare LH mirror, so used that to make up the set. It has better paint and the relay control plug does not have the correct wiring code as per the diagram in the thread link. I have provided another wiring diagram with colour codes and as said previously, the set is already prewired to test with postive and negative. Uses 87989-20020.
While I am here, there are some other bits and bobs to show in working order:
Spare Switch Working
Supra Switch Working (which incidently is the same as the celica switch).
DeeCee
Postby Dups90gt » Sat Jan 23, 2010 6:32 am
shoots and I just bought a set of non folding ones a few weeks ago, wish i saw this then. How can you tell if the mirrors are folding or non folding if it doesn't come with the module and switch? does it click (like your forcing gears) when you force the mirrors to fold by hand or does it just slide normally? My plugs look identical to yours and the mirrors are heavy. would you know what wire controls the retract and extend on the mirror harness and what voltage it uses?
Dups90gt
Postby shadowlife25 » Sat Jan 23, 2010 8:21 pm
Nicely done DeeCee. Good list and wiring info. Bump for a great fella.
- Mario
shadowlife25
Postby DeeCee » Tue Jan 26, 2010 1:19 am
Bump - $150 shipped to US or Canada :)
DeeCee
Postby Dups90gt » Tue Jan 26, 2010 2:22 am
Bump for a soon to be crowned KING.
Dups90gt
Postby DeeCee » Mon Feb 01, 2010 8:01 pm
Bump for mirrors - Camber plates delivered in a week from NZ. You too could have some nice working mirrors in a weeks time :)
DeeCee
Postby athousandleaves » Mon Feb 08, 2010 6:24 am
I'm a touch confused... I didn't know the glass was different from LHD to RHD folding mirrors, is there no way to recalibrate the initial position of the glass to get it so its workable on an LHD car?
I already have a few sets of these mirrors coming to me so it'd be good to know how much work they're going to be.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby Dups90gt » Mon Feb 08, 2010 10:43 am
the drivers mirror is convex and the passengers mirror in not, I ordered a new convex mirror to replace the passenger one and added spacers inside to get the proper angle as the rhd ones dont have the correct angle.. I will post pics once my glass arrives.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=220541384605&ssPageName=ADME:B:WNAFP:CA:1123
Dups90gt
Postby athousandleaves » Mon Feb 08, 2010 2:12 pm
So just to clarify...
On an RHD celica the drivers side is a regular flat mirror but the passengers side is convex so when its transferred to the LHD car the passenger side (LHD drivers side) glass needs to be replaced.
1992 White turbo4WD
athousandleaves
Postby Dups90gt » Mon Feb 08, 2010 6:01 pm
LEft (USD Drivers) is convex and right(USD Passengers side) is magnified, that plus you have to shim the screws that hold the mirror motor in place on the left side to get more of an angle for both mirrors or it wont move enough. if you want to see what I mean go sit in the passengers side of your car and try and adjust your mirrors as if it was a RHD car, the mirrors will reach a limit before you can see properly and thats how much or how big of a spacer you will need to put on the right side of the motor. To remove the plastic push the mirror so it faces up (looking up and pop off the plastic slowly from the bottom, theres a clip that holds it down at the bottom , then user a heat gun and a suction cup to remove the glass from the plastic or remove the glass first then remove the plastic.
Dups90gt
Postby Dups90gt » Wed Feb 10, 2010 2:42 am
athousandleaves wrote:I'm a touch confused... I didn't know the glass was different from LHD to RHD folding mirrors, is there no way to recalibrate the initial position of the glass to get it so its workable on an LHD car?
Here I did a write up for you:
http://www.alltrac.net/phpBB2/viewtopic.php?f=49&t=37122
Cheap fix so you can use them on LHD cars, cost less then $20 Canadian (and that was due to shipping)
Everyone should have these mirrors!
Dups90gt
Postby Dups90gt » Fri Mar 12, 2010 9:18 pm
Dee Cee received my stuff today! Thanks! you are the king! haven't wired it up yet but ill test it tonight!
..... I guess its time to change my pic below.
Dups90gt
Postby 1BADGT4 » Mon May 17, 2010 8:08 am
Happen to have anymore/left?
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Return to Global For Sale/Wanted
