Custom Sparco/OMP/Corba/Sabelt/etc. Seat brakets for Celica
Any country, GT-Four for sale or parts
Postby BNZ » Tue May 24, 2011 1:41 pm
Annoyed that the Celica floor is asymmetric and making holes trough the floor to get some brackets fixed is a barbaric way to go I've designed custom brackets for my rally ST165 and now i am mass produce them for whoever wants them.
Material is 5 mm hard aluminum according to FIA regulations and one set (6 pieces) compatible with any seat on the market (3 holding standards,either side holding screws or under-seat holding screws) is $100 + shipping (~$20 to US - non priority mail)
In the pictures is the prototype made from thiner aluminium to check all clearances.This one is not for sale.
P.S. I also can include all the screws in the package but i think they weight(shipping cost) more than they cost at a local store
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Re: Custom Sparco/OMP/Corba/Sabelt/etc. Seat brakets for Celica
Postby monkey8oi » Tue May 24, 2011 5:43 pm
DEFINITELY interested!!!! how much for a complete set w/bolts & hardware, etc shipped to california 95014??
monkey8oi
Postby BNZ » Tue May 24, 2011 6:12 pm
Will check the exact weight of the package including all the bolts and nuts tomorrow.
Basically shipping to US non-priority mail is 11$ for the first Kg + 7$ every additional kg
Meanwhile you can check the skid plates i made : viewtopic.php?f=24&t=28215&p=390992#p390992
Street ST185
Rally ST165
BNZ
Images: 31
Postby CMS-GT4 » Tue May 24, 2011 7:01 pm
Looks promising.
Postby alltracst185 » Tue May 24, 2011 10:14 pm
St185 and st165's are the same too :wink: I tried mine for my st185 in my st165 before i lost it and they bolted right up :D
alltracst185
Postby aus jd 2703 » Wed May 25, 2011 12:07 am
hey BNZ,
off topic but how do gt fours go with having the handbrake used? does it damage the drive-train or wear the VC out or anything? always wanted to do a handbrake turn but not game in-case it breaks the transmission
aus jd 2703
Postby BNZ » Wed May 25, 2011 4:49 am
The VC is a forgiving differential but only use the handbrake for short time,just to put the car sideways,don't hold it for longer time and you will avoid wearing the diff.
More info here : viewtopic.php?f=43&t=36915
Street ST185
Rally ST165
BNZ
Images: 31
Postby BNZ » Wed May 25, 2011 4:53 pm
One set : 3kg
So to sum up :
Kit for 1 seat : 125$ delivered to US
Kit for 2 seats : 246$ delivered to US
Payment via Paypal the easiest way.
If someone wants to order this is my mail : tm8bnz [ at ] gmail.com or here on this forum...
Street ST185
Rally ST165
BNZ
Images: 31
Postby Autobot » Sat May 28, 2011 6:03 pm
Hey, just curious if this would work with 7th Gen Celica seats in an ST185?
Autobot
Postby BNZ » Sat May 28, 2011 7:23 pm
I've made them using the standards used in motorsport seats...using them on stock heavy seats it's a bad idea and i don't think it works whatsoever
Street ST185
Rally ST165
BNZ
Images: 31
Postby BNZ » Wed Jun 08, 2011 6:53 am
Race tested this wkend ! Perfect hold :)
UP
Street ST185
Rally ST165
BNZ
Images: 31
Postby BNZ » Fri Aug 26, 2011 7:09 am
UP
Street ST185
Rally ST165
BNZ
Images: 31
Postby klue » Sat Mar 10, 2012 1:31 am
Hey great looking product,
How low do these get? I have issues with my head to roof clearance in my GT4. 6"2 inch height driver
Postby BNZ » Fri Mar 16, 2012 7:31 am
Had that issue too in my ST165, now the problem is gone with those brakets. I can make the holes as low as you want but basically you will be limited by the seat's bottom end reaching the flor
Street ST185
Rally ST165
BNZ
Images: 31
Postby underscore » Fri Mar 16, 2012 1:10 pm
you said these work on the 185 as well, can they work with a slider rail?
Return to Global For Sale/Wanted
