xiiimotorsports SOLID rear end bushing kits *GB closed*
Proposed and organized group buys
Postby klue » Sat Nov 24, 2012 4:21 pm
Hello everyone!
I have received quite a few inquiries about doing another run for the bushing kits. Everything is already been set up, so it should be a lot less work for me to make these for you guys(and thus less time between production). Lets see if we can have a successful run again for 10 or so. I am willing to buy two sets myself just to have them in case someone asks later. I understand that some people cant afford to wait as their cars are daily driven.
We did have a few issues on the last thread, hopefully everyone has their big boy pants on and we can keep this thread STRICTLY business. Please if you have any questions pertaining to the products post them here anything else does not belong on this thread.
Objectives: Replace worn out rear end bushings which cause excessive vibration, noise, sway, drive train mis alignment, and unwanted handling characteristics. Solidifying the rear end using the Acetal bushings gives the firmest connection to the rear end, with superior durability and material characteristics over nylon and polyurethane. Installing this complete kit will restore factory alignment in the drive train, improve throttle response and rear end feedback.
Thanks to Jordan for the picture
The features of our product:
- Finest quality and machining tolerance made right here in Canada with USA materials
-Bushings made of Acetal Copolymer certified to ASTM d6778 (Data sheets and mill test reports available )
-Diff plate made of aluminum 6061 alloy certified to ASTM b209 (Data sheets and mill test reports available )
To get your name on the group buy list you MUST send me a deposit of $30 USD. PM me for my paypal info.
I will be holding deposits via PAYPAL but accepting all major credit cards to avoid shortchanging myself with fees.
Your deposit will cover shipping charges to the USA, To Canada you will have $10 refunded to you
Email format is the following
*** At this stage in the group buy if there is interest in just the SUBFRAME, or just the DIFF kit we can accommodate this***
Name:
Username:
Phone number:
Complete shipping address:
Payment preferred:
Full Diff Upgrade kit ($365) USD
1. 801alltrac
2.
3.
4.
5.
6.
7.
8.
9.
10.
If anyone whom has PURCHASED a kit would like to leave some feedback on your experience good or bad please do. Only through you feedback can we improve our products for the alltrac community.
IF you do not pay by the deadline(TBA) you will loose your spot, and your deposit. I will not budge on this as I got screwed over the last run. Do not send your deposit if you can not make the payment when due.
Thank you guys for your support, as long as its there we can continue.
Tune in on Facebook
http://www.facebook.com/xiiimotorsports
Luke
Torque specs
Thanks Dave
Re: xiiimotorsports SOLID rear end bushing kits
Postby kn0wledge185 » Sat Nov 24, 2012 6:21 pm
1. 801alltrac
2. kn0wledge185
3.
4.
5.
6.
7.
8.
9.
10.
kn0wledge185
Postby defective » Mon Nov 26, 2012 12:49 am
1. 801alltrac
2. kn0wledge185
3. defective
4.
5.
6.
7.
8.
9.
10
1992 Celica GT4
defective
Postby kn0wledge185 » Tue Nov 27, 2012 4:46 pm
Bump
kn0wledge185
Postby celigts » Tue Nov 27, 2012 5:49 pm
Everyone is still recovering from this summer and fall lol. Plus we just did this AND Xmas is around the corner
3SGTE project motor very slow
celigts
Postby klue » Tue Nov 27, 2012 10:19 pm
celigts wrote:Everyone is still recovering from this summer and fall lol. Plus we just did this AND Xmas is around the corner
Yea I had at least 5 people ask me about it, so I figured I would put the up here. The last thread took a few months to come together so we can all be patient. I'm certainly in no rush, as we do have another project already in development
Postby lumbercis » Wed Nov 28, 2012 2:16 am
What's the benefit of Acetal over nylon or poly? My main concern isn't stiffness but wear. I'd like to put something back there I never have take out again because the material has compacted and gotten loose letting the subframe move around again. I have a set of nylon bushings but haven't installed them yet.
I'd actually be interested in a run of full aluminum subframe bushings.
Caldina powered...
lumbercis
Postby celigts » Wed Nov 28, 2012 2:55 am
lumbercis wrote:What's the benefit of Acetal over nylon or poly? My main concern isn't stiffness but wear. I'd like to put something back there I never have take out again because the material has compacted and gotten loose letting the subframe move around again. I have a set of nylon bushings but haven't installed them yet.
That would be intense!
celigts
Postby klue » Wed Nov 28, 2012 10:20 pm
Im completely open to suggestions! all the measurements are done, so making aluminum ones would be a definite possibility. The labor would be less, but the material costs would be higher.
The reason I chose acetal over nylon is that is absorbs far less moisture than nylon. I have had issues with nylon bushings swelling and deforming over time, I had replaced them before failure, but others not so lucky. Could be the climate or something, but I just rather not use it. Aluminum I think has no real advantage over the acetal bushing we are producing, I really cant for see you having any issues with these. I've tested them on numerous cars for regular use, and on my own car it gets the hammer every time it runs.
Postby celigts » Thu Nov 29, 2012 2:14 am
Acetal suspension bushings next in line for custom bushings ? Or poly is tough enough?
celigts
Postby klue » Thu Nov 29, 2012 10:11 pm
Oh yea I did not even comment on the POLY stuff. My main issue with poly is 2 things,
A) the casting. I have had bushings from reputable suppliers come with air pockets inside
b) it just dont cut the mustard... I need SOLID not semi solid. lol
Celigts, I can already source aftermarket suspension bushings for all areas of the vehicle so there is not point in doing them over. Maybe at some point I will make solid ones but not at this time.
For the track I would just use ball ends anyway
Postby aus jd 2703 » Thu Nov 29, 2012 11:56 pm
mmmmm rosejoint suspension mmmmmm.
any way how much to ship to Australia Klue? might have 2 people interested so can we combine orders into one box?
aus jd 2703
Postby klue » Fri Nov 30, 2012 12:06 am
aus jd 2703 wrote:mmmmm rosejoint suspension mmmmmm.
We definitely can! Send me your postal code and we will check up on that for you right away!
Postby Punknoodle » Fri Nov 30, 2012 12:13 am
I'm one of them klue^^ (with aus jd and another non member)
Punknoodle
Postby klue » Fri Nov 30, 2012 12:17 am
Punknoodle wrote:I'm one of them klue^^ (with aus jd and another non member)
in that case enjoy some eye candy
Thanks for the pics John
Return to Group Buys
