xiiimotorsports SOLID engine mounting kit
Proposed and organized group buys
Re: xiiimotorsports SOLID engine mounting kit
Postby klue » Sat Jun 08, 2013 1:24 pm
cgtdream wrote:
aus jd 2703 wrote:205/185 mounts arnt the same. I had to swap them all to 185 so it would fit in my 185.. The inserts in the mounts might be the same but the mounts complete. Are not interchangeable.
You are correct sir..Just did a toyodiy comparison and stock for stock pic comparison and what you say fits....the actual insert are interchangable, but the mounts themselves are not...so now the question is. Are these just the inserts or a complete mount?
We are doing INSERTS, I could produce a whole mount of billet, but the cost would at least quadruple for no gain. From a practical standpoint the stock housing is more than sufficient it is the inset that fails. I have a set of 205 mounts in storage, does any one have any handy and can post up some pics?
Luke
Postby cgtdream » Sat Jun 08, 2013 1:56 pm
Alright pics of set of TRD ones.....And yes the rightside mount is wayy different from the alltracs...But the others are same dimension (inserts wise at least)
cgtdream
Postby klue » Sat Jun 08, 2013 2:11 pm
Yea the right definitely looks different, familiar as i have worked on a few 205s before.
We could make that mount, but it would require building the entire mount.
Postby cgtdream » Sat Jun 08, 2013 2:23 pm
To be completely honest, i have no idea if that mount would even need to be replaced...ive never seen a design like that before..any ideas on if it would even need to be replaced?
cgtdream
Postby klue » Sat Jun 08, 2013 2:30 pm
cgtdream wrote:To be completely honest, i have no idea if that mount would even need to be replaced...ive never seen a design like that before..any ideas on if it would even need to be replaced?
on a track car, weight for sure.
Postby cgtdream » Sat Jun 08, 2013 2:35 pm
So you are saying you could make a more durable yet lightweight mount in its place? If so that would be awesome, considering how heavy that one piece is.
cgtdream
Postby klue » Sat Jun 08, 2013 2:37 pm
cgtdream wrote:So you are saying you could make a more durable yet lightweight mount in its place? If so that would be awesome, considering how heavy that one piece is.
In short, YES.
To justify it we would need enough orders to make the price not one off cost. As well as time to prototype, test, before we release.
Postby cgtdream » Sat Jun 08, 2013 2:42 pm
Makes sense...in the meantime im still down for a set (of four i guess) of your current mounts. If anything i can be a guinea pig on if they fit and work correctly on the 205's..
Even down to be a test pig for a fourth if it comes to it...
cgtdream
Postby klue » Sat Jun 08, 2013 8:00 pm
1. GT4_DRED
2.Theman88b
3. thespen
4.splitfiremk16
5.muskokagt4
6.alltrac101
7. l00k0v3rth3r3
8.l0ch0w
9.fhalperformance
10.cgtdream
10 on the list!
Postby klue » Sat Jun 15, 2013 1:12 am
Went by the shop today to figure out how we want these to fit. They will be press fit, as get it square and tap in with a soft hammer or block of wood.
Material is on order as soon as it arrives production is go!
Postby l0ch0w » Sat Jun 15, 2013 1:29 am
If they wind up being off centered for whatever reason, will you include match marks on them? or some sort of way to locate them?
Andrew
1991 Red Alltrac
l0ch0w
Postby klue » Sat Jun 15, 2013 1:59 pm
l0ch0w wrote:If they wind up being off centered for whatever reason, will you include match marks on them? or some sort of way to locate them?
They will be centered, chamfer on both sides so you can install either way
Postby l0ch0w » Sat Jun 15, 2013 6:31 pm
Will these be white only? or do you think that black (or red) could be used?
Andrew
1991 Red Alltrac
l0ch0w
Postby klue » Sat Jun 15, 2013 6:39 pm
We use black acetal not white. They will only be available in white. You could probably paint them with a plastic paint or plastidip if you really wanted
Postby coutoGT4 » Sat Jun 15, 2013 7:41 pm
Are you still taking on more for this group buy?
coutoGT4
Return to Group Buys
