mini SuperPro and Whiteline polyurethane group buy
Proposed and organized group buys
Postby kilt88 » Mon May 20, 2013 3:40 pm
(edit 01) added retail prices section
(edit 02) added Who's In section
(edit 03) added Whiteline equivalents and pricing
A couple of us need some SuperPro poly bushings, so I'm going to put an order in with a local dealer.
And if you're in the Denver area, you won't have to pay shipping if you want to pick them up from me, or meet me somewhere.
You can lookup parts here: http://www.superpro.com.au
Please let me know what you want, and if you are not sure about something, just ask ... I used to resell kits, so I know what goes where.
Notes:
1) That SuperPro site shows "Control Arm-Outer Bushing" for the rear. DO NOT USE THESE, as you would be converting spherical bearing (heim) joints to swivel joints. Instead, order Toyota p/n 42210-14010 qty 4.
2) ST165 guys ... for the front control arm inner rears, you definitely should take advantage of the added caster version, SPF1365AK.
Here's how to buy everything possible:
ST165
front SPF1044K (Whiteline W52973)
front SPF1365AK
front SPF1335-xxK (xx = swaybar diameter in mm) (Whiteline W21058 [24mm])
rear SPF0823K (Whiteline W61446)
rear SPF2264K
rear SPF2265K
rear SPF0331-xxK (xx = swaybar diameter in mm) (Whiteline W21419 [14mm])
ST185
front SPF1435K (Whiteline W51976)
front SPF1320K (Whiteline W51975)
front SPF1335-xxK (xx = swaybar diameter in mm) (Whiteline W21212 [25mm])
rear SPF2264K
rear SPF2265K
rear SPF0462-xxK (xx = swaybar diameter in mm) (Whiteline W21259 [16mm] or W21086 [18mm])
Of course, you can buy non-Alltrac parts, too.
Prices
Here are the DISCOUNTED prices for SuperPro. LET ME KNOW IF YOU NEED A PART ADDED TO THE LIST. http://superpro.com.au
SPF0331-13K $23.70
SPF0331-14K $23.70
SPF0331-17K $23.70
SPF0331-18K $23.70
SPF0331-19K $23.70
SPF0331-20K $31.81
SPF0462-12K $25.22
SPF0462-14K $22.97
SPF0462-15K $25.22
SPF0462-16K $22.97
SPF0462-17K $23.36
SPF0462-18K $25.22
SPF0462-19K $33.22
SPF0462-22K $25.22
SPF0823K $88.70
SPF1044K $50.52
SPF1221K $40.64
SPF1320K $62.15
SPF1335-24K $23.71
SPF1335-25K $23.71
SPF1335-26K $21.96
SPF1365AK $64.08
SPF1435K $68.94
SPF2264K $87.55
SPF2265K $84.48
SPF2730K $71.00
SPF2731K $83.54
SPF2742K $142.72
I can also get us 25% off Whiteline, but there are not as many parts available as SuperPro. So maybe just choose Whiteline where it's cheaper.
Here are the DISCOUNTED Whiteline prices. LET ME KNOW IF YOU NEED A PART ADDED TO THE LIST. http://www.whiteline.com.au
W21058 $17.18
W21086 $17.18
W21212 $17.18
W21259 $17.18
W21419 $17.18
W51975 $41.18
W51976 $44.93
W52973 $29.93
W61446 $59.93
Who's In
Code: Select all
Hiko                              SPF1335-24K                                                  W51975 W51976 W61446
___Scott___ SPF0331-19K SPF1365AK                         SPF1335-26K                   W52973               W61446
kilt88                                        SPF1335-25K             SPF2264K SPF2265K
Josh
from 185 Performance, many moons ago
92 ST185
Current Project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46970
Duluth, GA
kilt88
Re: mini SuperPro polyurethane group buy
Postby Hiko » Mon May 20, 2013 8:06 pm
I would like in :)
As I have a ST184, think I'll be wanting
front SPF1435K
front SPF1320K
front SPF1335-24K
Rear SPF2730K
Rear SPF0823K
Rear SPF2742K [st204 upgrade planned]
As far as "Control Arm-Outer Bushings", I noticed the website said the same thing, but I really seem to remember that my arm bushings are just plain ol' rubber, what am I missing?
Thanks much!
Hiko
Postby kilt88 » Mon May 20, 2013 8:37 pm
Hiko wrote:I would like in :)
front SPF1435K
front SPF1320K
front SPF1335-24K
Rear SPF2730K
Rear SPF0823K
Thanks much!
Not sure if you meant to leave off the rear, inner rear: "Control Arm-Inner Rear Arm Kit" SPF1221K
You know, I also kinda remember this about the st184. I think there's just one, big bolt that goes through both control arms, with the hub carrier in between. Ok, ya, here's an image from the EPC. If you can confirm the outer joints of the rear control arms are not heim joints, then go for it, and add SPF2731K.
Josh
92 ST185
Duluth, GA
kilt88
Postby Theman88b » Tue May 21, 2013 12:39 am
I am interested in a ST165 kit but curious about the price. How much for each full kit? I noticed some kits are over $400.00 at Figs Engineering.
'88 Toyota Celica All Trac Turbo(Blue) 145k - Rebuilt and Bored 1mm over, big psi soon!!
'92 Ford Taurus SHO(White) 212k - Some mods but still my DD
Theman88b
Images: 3
Postby RallyX-GT4 » Tue May 21, 2013 1:46 am
Yeah, I'd be interested in knowing the price of a full kit for the ST165 as well...
1988 - ST165 - RallyCross #3
RallyX-GT4
Postby kilt88 » Tue May 21, 2013 1:53 am
Let me see if I can get some initial prices tomorrow. I wanted to get a qty before I approached Figs.
Josh
92 ST185
Duluth, GA
kilt88
Postby Hiko » Tue May 21, 2013 3:52 am
It looks like 2742k should be the inner rear for the st204 arm which I'll be swapping. And from the pictures I've been seeing, looks like I don't have heim joints, so I will go ahead and add 2731k
Hiko
Postby kilt88 » Tue May 21, 2013 4:23 am
Hiko wrote:It looks like 2742k should be the inner rear for the st204 arm which I'll be swapping. And from the pictures I've been seeing, looks like I don't have heim joints, so I will go ahead and add 2731k
Oh, you're putting an st204 arm on the st184.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Tue May 21, 2013 1:44 pm
Ok, Mike at Figs emailed me back, and he's going to get us pricing by mid-week.
Josh
92 ST185
Duluth, GA
kilt88
Postby eric thompson » Tue May 21, 2013 3:52 pm
Count me in!
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby ZeroDrift » Tue May 21, 2013 4:08 pm
I'm interested in the ST165 set with the caster bushings.
Postby GT4_DRED » Tue May 21, 2013 4:31 pm
ZeroDrift wrote:I'm interested in the ST165 set with the caster bushings.
same here..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby kilt88 » Tue May 21, 2013 6:37 pm
I just added initial pricing to the first post.
Josh
92 ST185
Duluth, GA
kilt88
Postby kilt88 » Tue May 21, 2013 8:12 pm
Ok, guys, please reply with the part numbers you want, and I'll get you added to the list in the first post.
Josh
92 ST185
Duluth, GA
kilt88
Re: mini SuperPro and Whiteline polyurethane group buy
Postby kilt88 » Tue May 21, 2013 9:02 pm
I added Whiteline equivalents to the list, along with pricing.
Josh
92 ST185
Duluth, GA
kilt88
Return to Group Buys
