mini SuperPro and Whiteline polyurethane group buy
Proposed and organized group buys
Re: mini SuperPro and Whiteline polyurethane group buy
Postby ___Scott___ » Tue May 21, 2013 10:39 pm
Thanks for thinking about Whiteline, it hadn't occured to me that they may offer polyurethane bushings cheaper than SuperPro. Since the "Control Arm Lower-Front Bushing" and "Trailing Arm - Bushing Kit" are cheaper from Whiteline, please swap the following part#s:
SPF1044K to W52973
SPF0823K to W61446
Thanks
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Hiko » Wed May 22, 2013 5:06 am
Right-o, after some review, I'll skip the rear control arms (I'll try making my own) and switch a few to whiteline making my list
W51976
W51975
W61446
SPF0823K
SPF1335-24K
Hiko
Postby kilt88 » Wed May 22, 2013 11:19 am
Hiko wrote:Right-o, after some review, I'll skip the rear control arms (I'll try making my own) and switch a few to whiteline making my list
W51976
W51975
W61446
SPF0823K
SPF1335-24K
Hiko, W61446 = SPF0823K. I assume you just want W61446, correct?
Josh
from 185 Performance, many moons ago
92 ST185
Current Project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46970
Duluth, GA
kilt88
Postby Hiko » Thu May 23, 2013 3:05 am
kilt88 wrote:Hiko, W61446 = SPF0823K. I assume you just want W61446, correct?
:oops:
Yeah, that would be what I need.
Thanks!
Hiko
Postby kilt88 » Thu May 23, 2013 3:10 am
So what about the rest of you guys?
Josh
92 ST185
Duluth, GA
kilt88
Postby ___Scott___ » Thu May 23, 2013 5:32 pm
If you have seen this opportunity and decided to skip it, why?
If you have already upgraded to polyurethane bushings, I understand that. Can't spare the money right now, I get that. But otherwise if you are still cruising around with stock rubber bushings then you really should give this opportunity a closer look. It was a big improvement when I upgraded my old ST165 and I should have upgraded my "new" one sooner. You'll get much improved mid-corner stability and generally quicker steering response. The penalty in ride harshness is minimal, similar to adding two psi of air pressure to your tires.
We don't need a set number of people to make this happen, so I'm not twisting any arms here. I just think it's a worth while upgrade. Give it some thought.
Scott
SONY
___Scott___
Postby RallyX-GT4 » Thu May 23, 2013 7:42 pm
Yeah, I get that this is a good opportunity since there are no uprated rubber bushing available after TRD abandoned all of us - just don't have $400.00+ laying around. That being said, I should be able to do this in a week or so...
Quick question, are the durometers of the Super Pro vs. the Witeline the same?
1988 - ST165 - RallyCross #3
RallyX-GT4
Postby kilt88 » Thu May 23, 2013 7:51 pm
RallyX-GT4 wrote:Quick question, are the durometers of the Super Pro vs. the Witeline the same?
I have never been able to confirm this, but have long speculated that SuperPro makes bushings for Whiteline. Years ago, when I would order a Whiteline part number, and it came in yellow, rather than the SuperPro blue, there was the SuperPro part number stamped on the side of it. But that was around 2004 or 5. My guess is that only the color differs.
Josh
92 ST185
Duluth, GA
kilt88
Postby ___Scott___ » Mon Jun 03, 2013 4:01 pm
Bump!
Scott
SONY
___Scott___
Postby RallyX-GT4 » Mon Jun 03, 2013 4:33 pm
How much longer will this GB be going?
RallyX-GT4
Postby kilt88 » Mon Jun 03, 2013 6:19 pm
Oh, it has barely gotten started. :smile:
Josh
92 ST185
Duluth, GA
kilt88
Postby celicamonkey » Wed Jun 05, 2013 1:08 pm
I'm in for at least SPF1435K and SPF1320K.
Dustin
2008 Legacy GT
1990 Celica All-Trac
1990 Celica GT
celicamonkey
Postby Toxygene » Wed Jun 05, 2013 3:43 pm
I am going to try and restomod my Alltrac. What would a full kit for the ST185 be priced at?
Toxygene
Postby kn0wledge185 » Thu Jun 06, 2013 3:41 am
I'm also interested in a whole kit.... except for control arm-outer bushing
kn0wledge185
Postby kilt88 » Thu Jun 06, 2013 5:50 am
I am away on vacation, but can do the math for you guys early next week. Let me know your swaybar diameters.
Josh
92 ST185
Duluth, GA
kilt88
Return to Group Buys
