Reproduction Aluminum Fuel Tank
Proposed and organized group buys
Postby fhalperformance » Wed Mar 26, 2014 6:43 pm
I am in contact with a company about getting a reproduction aluminum fuel tank made and am curious who else is interested in a new tank. I have no pricing information right now as we are still working on a the specs, pricing & lead time. Unfortunately the fabrication shop that deals specifically with custom tanks is not local to me although I do have feelers out to local shops at the moment. If you are interested please post up with any comments or suggestions you may have. I need a fuel tank within the next 2 months if Im going to have my car ready for watkins glen in june so Im pretty motivated. Once I have my tank installed I will have all the details sorted for a group buy.
Working Specs:
Fit in the stock location
May require new fuel tank straps
Will probably reuse the fuel level sender
Will not be an exact replica of the tank
May have a capacity bump just for ease of construction
Factory filler neck location
Fuel Feed & Return lines off sender, rollover valve for fuel tank vapors
Ideas I was kicking around:
Increase the width of the tank with a slanted bottom to allow for clearance for a diffuser
Have a wider fuel sender so more pumps can be installed on it
Foam for the tank to prevent fuel slosh
Link to the shop Im talking to.
http://www.boydwelding.com/
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Re: Reproduction Aluminum Fuel Tank
Postby GT4_DRED » Wed Mar 26, 2014 6:51 pm
Would be nice to have an untapped sump in it as well.. I like!
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby fhalperformance » Wed Mar 26, 2014 10:12 pm
Looks like multiple order discounts don't kick in till you buy 10 tanks. I'm making an accurate dimensioned drawing to send for an exact price while I wait for an estimated cost given the rough exterior dimensions I gave them.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby warracer » Wed Mar 26, 2014 10:19 pm
Depending on the timing, yeah I would buy one!
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby littlemissalltrac » Wed Mar 26, 2014 10:39 pm
umm yes put me in for one of these. Im very curious to hear more details on pricing. If they want to have it picked up and shipped(or you?) i have 2 OEM tanks (rusted) i would donate one to them for measurements. The tanks cant really be used again but it would let them get fitment down pretty good with the real deal infront of them. Let me know if there interested or you are.
littlemissalltrac
Postby zero06 » Wed Mar 26, 2014 11:03 pm
im in
zero06
Postby underscore » Thu Mar 27, 2014 3:56 am
I'm interested, are there any known downsides to an aluminum tank? Since the design is being modified a bit from stock, could we get it made level (vs that stupid slant the stock one has). Would it be a bare tank, or would it have a cover similar to the stock one?
Postby ALLensTRAC » Thu Mar 27, 2014 10:23 am
underscore wrote:I'm interested, are there any known downsides to an aluminum tank? Since the design is being modified a bit from stock, could we get it made level (vs that stupid slant the stock one has). Would it be a bare tank, or would it have a cover similar to the stock one?
Man I'm glad I'm not the only one who can't stand that!!!
I might be in for one but it would depend on if they make it with clearance for a diffuser and level mounting as underscore said.
Allen
ALLensTRAC
Postby fhalperformance » Thu Mar 27, 2014 10:48 pm
Im glad there is a good amount of interest already. I am entertaining two options at the moment that range from complete solutions from the supplier to just a tank. I am planning to get the sketch nailed down this weekend so I can post it up here and send it to the two companies Im in contact with to see what price tag we are talking about. Depending on turn around time and pricing I may order one from each place to see which I like better. There probably wont be any cover made since it shouldnt really need one. I had kicked an idea around about making tank straps that had an incorporated diffuser in it but it seems that everyone wants the bottom of their tank flatter then factory which may or may not make that harder to accomplish.
First Option: The place I have been in contact about an aluminum tank wants the detailed sketch of the fuel tank before they speculate on a price. I linked to their website earlier which has examples of their work and its a professional product which is why I was interested in them in the first place. I imagine their tank will be pricey in comparison to the second option.
Second Option: I have also finally heard back from one of the local places I contacted as well. They say they can make a tank out of mild steel that would have to be powder coated. They dont normally make fuel tanks which has me concerned but they have made some before. Id have to source senders and do a little more work to make it happen.
Any ideas on a replacement fuel level sensor would be appreciated.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby underscore » Fri Mar 28, 2014 1:27 am
If we can get tank straps that accommodate a diffuser then presumably the tank itself wouldn't be visible, at which point I don't really care what shape it has to take since nobody could see it.
What's the issue with using the stock fuel sender?
Postby fhalperformance » Fri Mar 28, 2014 3:25 am
The wires rotted right off mine. My tank is straight garbage.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby ___Scott___ » Fri Mar 28, 2014 3:38 am
For an idea of how group buys customarily work with Boyd Welding, here is a link that spells it out:
http://www.ffcars.com/forums/120-factor ... ost3047897
The guys building 33 Hot Rods regard the custom Boyd tanks as the best at any price. Most people discard the tank that comes with the 33 Hot Rod kit and buy one of Boyds.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby fhalperformance » Fri Mar 28, 2014 10:30 pm
Boyd Welding is telling me 400-600 given the rough dimensions & the complexity of the tank. Im trying to get a full description of what that includes. That's all the new information I have as of this moment more updates to come this weekend.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby athousandleaves » Sun Mar 30, 2014 9:43 pm
I'm interested but damn $400-600 is steep! :doh:
edit
Still cheaper than an ATL cell but those are explosion and impact proof, what kind of safety features would they put into these tanks?
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby fhalperformance » Mon Mar 31, 2014 1:46 am
EDIT: (ATL fuel cells are explosion and impact proof...) When mounted inside of the roll cage structure.
If it comes with senders (waiting on a detailed break down of the product) it is $400+ cheaper then new oem and they arent available. Its cheaper then just a new bare tank either way. No more safety features planned except for maybe a roll over valve and thicker material construction compared to factory. The extrusions on the front of the tank will be used to attach the car to the chassis & add mounts for a diffuser setup possibly. Should prove to be a better setup then gas tank straps. I still have to measure those for position but now that the model is done I can just go back and modify the dimensions to make any changes I want.
I got a rough sketch done based on some quick measurements of the tank. I didnt have time to position the tank back in place as I got stuck working on a family members car last minute. The design of the tank doesnt appear to truly follow the "hole" it bolts into on the car and want to see exactly what clearance issues there are if I simplify the tank design.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Return to Group Buys
