xiiimotorsports GEN 3 TB inlet
Proposed and organized group buys
Postby klue » Sun Feb 15, 2015 7:53 pm
Production is ready.
I would like to offer a discount for initial purchases on the xiiimotorsports GEN 3 Throttle Body Inlet. These can be used to facilitate a FMIC install, custom WTA, or factory water to air. The production version will be 2" long from flange base to the end of the tube. If you require a shorter version please note that and we can have one cut to the length you specificity.
The throttle body inlet features a smooth transition from your intercooler piping to the inlet of the throttle body with no sharp edges to cause turbulence or otherwise disrupt the flow. The flange and tube are made of high quality light weight 6061 Aluminum, and precision TIG welded in house. Flanges are precision cut using a cnc water jet cutter to provide a perfect fit. Tube is machined on a CNC lathe, not formed. The inlet will come fully polished unless requested other wise.
USD
Price is $79 Retail
Group buy price is $70
http://www.xiiimotorsports.com/index.php/xiiimotorsports-gen-3-throttle-body-inlet.html
Dont mind the price on the website I had to get the numbers right so the shipping quote works properly
I will run the group buy for 1 week or until we can get 10 orders.
Any orders can be ordered through our website link is here
PAID in FULL
1.Matt Hasek (facebook)
2. WALKER (alltrac.net) (short)
3.ST_6396 (alltrac.net)
4.Luka (6gc.net)
5.Devon (facebook)
6.
7.
8.
9.
10.
Thank you for your continued support. Every purchase helps fund future developments
Luke
xiiimotorsports
Re: xiiimotorsports GEN 3 TB inlet
Postby FC Zach » Sun Feb 15, 2015 8:27 pm
Do you have one of these for a gen 2?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby klue » Mon Feb 16, 2015 2:40 am
FC Zach wrote:Do you have one of these for a gen 2?
Hey Zach,
Yes ive got one from another project
Postby klue » Mon Feb 16, 2015 2:43 am
1. Matt Hasek (facebook)
2.
3.
4.
5.
6.
7.
8.
9.
10.
Postby FC Zach » Mon Feb 16, 2015 2:47 am
Hey Zach,
I'd like one please.
FC Zach
Images: 9
Postby klue » Mon Feb 16, 2015 3:19 am
FC Zach wrote:
Hey Zach,
Send me a text Zach
Postby klue » Fri Feb 20, 2015 3:43 am
PAID in FULL
4.Luka (6gc.net)
5.Devon (facebook)
6.
7.
8.
9.
10.
5 more needed!
Postby klue » Tue Feb 24, 2015 2:17 am
PAID in FULL
4.Luka (6gc.net)
5.Devon (facebook)
6.Louis Bui (facebook)
7.Mike Hill (alltrac.net)
8.
9.
10.
only 4 more pre order spots!
Postby tmkjune » Fri Feb 27, 2015 4:29 pm
Where do I pay?
tmkjune
Postby zaluss » Fri Feb 27, 2015 6:57 pm
I'm also in. Where do I send the monies?
zaluss
Postby klue » Sat Feb 28, 2015 12:38 am
hey guys the link is in the first post. I need some help from one of you. I need the distance between the stock intercooler outlet and the face of the throttle body. In otherwords if you removed the rubber coupler and put everything back how much space is there between the edge of the intercooler outlet and the throttlebody face
Postby zaluss » Sat Feb 28, 2015 1:27 am
klue wrote:hey guys the link is in the first post. I need some help from one of you. I need the distance between the stock intercooler outlet and the face of the throttle body. In otherwords if you removed the rubber coupler and put everything back how much space is there between the edge of the intercooler outlet and the throttlebody face
Ordered. I don't have the motor yet but I'll measure it when it gets here if no one else does.
zaluss
Postby klue » Sat Feb 28, 2015 4:17 am
Thanks Id appreciate that
Postby klue » Sat Feb 28, 2015 5:28 am
PAID in FULL
4.Luka (6gc.net)
5.Devon (facebook)
7.Mike Hill (alltrac.net)(zaluss)
8.
9.
10.
Postby klue » Tue Mar 03, 2015 1:27 am
Updates:
Hey guys, going to the machine shop tomorrow to start production on the second part of the assembly. I'm going to work over making a change to the flange to incorporate an Oring seal, standard size so it would be easy to replace.
Secondly, and quite frankly. I need someone to step up and help me with some measurements. I need to get the distance between the throttle body face and the end of the intercooler outlet so that I know if its workable to cut the pipe short enough to fit a stock set up.
email me or PM
Thanks
Luke
Return to Group Buys
