Specs on wilwoods caliper brackets
Postby CMS-GT4 » Mon Aug 09, 2004 9:24 pm
Anyone have specs or dimensions of the wilwood caliper brackets? Ie. material width etc?
I need something simular to the ones here, but I am doing 12" rotors.
http://www.rocketeeroffroad.com/tproduc ... smain.html
Even if I had the info on the 13" brackets, I could just change it by an inch. BTW: I bought Lee's old setup.
Postby Zeus » Wed Aug 11, 2004 8:09 pm
lee was asking me when he still had his... and he sent me over a diagram of the calipers... otherwise contact rocket off road
Blake Brown
Zeus
Postby alltrac.net » Wed Aug 11, 2004 8:52 pm
You want something similar to Dennis Heath's setup?
CNC Aluminum I believe.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby ChrisD » Thu Aug 12, 2004 5:04 am
edit
ChrisD
Postby CMS-GT4 » Thu Aug 12, 2004 8:07 pm
robert@alltrac.net wrote:You want something similar to Dennis Heath's setup?
Sure. I just need something stong that will bolt up the calipers on a 12" rotor. I like th idea of light alum. as long as it is stong enough. Do you have anything like that in stock? :wink:
Postby Zeus » Sat Aug 14, 2004 12:42 pm
chris_dittrick wrote:fyi Dennis has since removed the Wilwood's since he is not impressed with the performance. Check out his site for info.
he has the same size i have... i took the pn off of his page (was kinda mad he would have the pn up there if he new they were too big) they seem to be too big for the mc and are very mushy... i think with a larger mc which i havent gotten around to do yet they will brake very hard!!
Blake Brown
Zeus
Postby AWDtoyota » Sat Aug 14, 2004 7:32 pm
Does the Wilwood calipers fit on a ST165?
Ft. Laud., FL
'88 ST165
'84 Celica GT-S
AWDtoyota
Postby alltrac.net » Sat Aug 14, 2004 7:46 pm
They will with an adapter. Dennis heath had a JDM 90 ST185 with brakes like the ST165. The bracket he made would have actually fit on the ST165.
alltrac.net
Site Admin
Postby the911s » Sat Aug 14, 2004 8:07 pm
If someone wants to subsidize this research, I will develop a brake adapter for the ST165 and/or ST185. I will design it on professional software, run finite element analysis on it, and produce drawings for an adapter anyone can make. The problem is, I don't have the cash for the parts. So if yall wanna get together and help me pay for the Willwood kit, I will give you an awesome adapter drawing that is easy to make on common machine tools.
If this doesn't sound good to you, let's work something out. I think this could really help the Alltrac community.
bling bling
the911s
Postby 935motorsports » Sat Aug 14, 2004 9:17 pm
How will you test fit the bracket? Do you have a spare hub assembly? If I made an adapter out of steel, could you make drawings for it that would make sense to a CNC machinist?
935motorsports
Postby the911s » Sun Aug 15, 2004 6:50 pm
Well... I would have to take my car apart to test fit the bracket. Which would be fine, because I will have to take my car apart anyways as soon as I am done working for the summer, when I do a bunch of maintenence on the car.
I have experience getting parts made, so yes, I can made a drawing that will make sense to a machinist.
bling bling
the911s
Postby alltrac.net » Sun Aug 15, 2004 7:05 pm
OK then.
I'm going to make a crude adapter to bolt a MA70 caliper on to ST165 (or try to) OR maybe a Supra TT caliper.
alltrac.net
Site Admin
Postby the911s » Mon Aug 16, 2004 3:21 am
MA70? Not sure what that is... if you are interested in getting some drawings made, lemme know by email. We can work something out. Just wanna know what the deal is before say I will help out. I am not sure I'd wanna make drawings and such for brakes I either don't have or am not interested in getting for this car.
bling bling
the911s
Postby Gary » Mon Aug 16, 2004 3:36 am
MA70 = 1987-1992 NA Supra
MA71 = 1987-1992 Turbo Supra
93 ST185
Gary
Postby ChrisD » Mon Aug 16, 2004 4:42 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
