Just installed the aluminum rear diff cushion from Mario
Postby DeeCee » Wed Jul 08, 2009 9:18 pm
Help? There is a rubber cushion on top of the subframe bushing you have to replace with the nylon bushing
DeeCee
Postby RedCelicaTRD » Wed Jul 08, 2009 11:41 pm
I didn't put the upper rubber "spacer" back on mine.
Postby Wolf_Tm250 » Thu Jul 09, 2009 5:07 am
DeeCee wrote:Image
Mate, 52282 is the spacer for the 2 REAR DIFF front bushings,as you can see from the pics you posted.
But, as I wrote, I was talking about, and my pic is referring to, the REAR SUBFRAME:
so we are talking about 52272!
And mine, ST205 stock, seems to be much thicker... even because it doesn't seem, to me, to be a rubber cushion over the bushing, but one piece.
Thanks.
Wolf_Tm250
Gt-Four ST205 [2.34kg/hp DynoDynamics]
http://www.youtube.com/WolfTm250
DynoJet whp are false, and closer to other dynos FW hp. Please specify what dyno are your Whp from.
http://www.factorypro.com/magazine/dynojet_dyno_inflated_hp_reason.html
Wolf_Tm250
Postby DeeCee » Thu Jul 09, 2009 9:29 pm
Apologies, was in a rush yesterday. No matter though.
Maybe it installs bottom up? How thick is the other piece to the bushing?
I only ask as the EPC shows mounting from bottom up.
DeeCee
Postby Wolf_Tm250 » Fri Jul 10, 2009 5:57 am
DeeCee wrote:Apologies, was in a rush yesterday. No matter though.
No problem Mate!
Same thing... Mario's cap has the same thickenss of the Mario's cup I showed in the pic...
Thanks.
Wolf_Tm250
Wolf_Tm250
Postby Gary ST165 » Fri Jul 10, 2009 8:35 am
i think marios 4 x nylon rear subframe bushings are copied from the ST185...
the ST205 does indeed have a thicker rubber stopper!
ST165 turbo 4WD
Gary ST165
Postby Wolf_Tm250 » Tue Jul 14, 2009 5:13 pm
Discovered!
The higher ST205 spacer is due to a steel disc drowned in the rubber:
that's why I thought a one piece of rubber!
I suppose I have to remove/clean the steel disc from the rubber part and re-use it over Mario's bushings...
Really hope he will chime in! :D
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Tue Jul 28, 2009 6:45 am
DeeCee wrote:Image
Hi,
I searched ANYWHERE in the 2 ST205 Toyota books I own, but I didn't find the correct torque for the 4 rear subframe bushings' nuts ( 90179-12045 ) and the 2 differential subframe front bushings' nuts ( 90179-12099)...
anyone knows?
Thanks...
Wolf_Tm250
Wolf_Tm250
Postby DeeCee » Sat Aug 01, 2009 1:49 am
these ones help? From the ST205 big green book.
DeeCee
Postby Wolf_Tm250 » Sat Aug 01, 2009 11:02 am
DeeCee wrote:these ones help? From the ST205 big green book.
Thanks DeeCee... but I have this book, and there are not the torque settings required...
Neither in the Green, nor in the blue book... very strange !!!
Wolf_Tm250
Wolf_Tm250
Postby YerRandO » Sat Aug 01, 2009 1:39 pm
There are standard bolt torque specs near the beging of the manual (IN-21) look up the bolt class/size and it gives you specs for it, even has a chart for properly determining bolt class. It's fairly common in service manuals to refer a generic chart for for some fasteners.
-James
YerRandO
Re: Just installed the aluminum rear diff cushion from Mario
Postby aus jd 2703 » Thu Jun 21, 2012 11:13 pm
thread revival instead of new thread.
looking at Mario's full rear bushing set so 6 for the cradle and the aluminum diff mount.
but im worried about the wear and tear as it will have no give.
has anyone had trouble with durability after installing this kit?
also are the cradle mounts delrin or can you now get a poly option?
thanks guys and girls
aus jd 2703
Postby Fox 21 Alpha » Sun Feb 10, 2013 10:27 pm
Has anyone ever figured out the torque settings for the 4 subframe to body bolts? Its not listed in any charts I can find and you can't go by bolt size that I'm away since its studs out of the body and your tightening the nut side of things...
Fox 21 Alpha
Postby toayoztan » Mon Feb 11, 2013 5:08 am
Fox 21 Alpha wrote:Has anyone ever figured out the torque settings for the 4 subframe to body bolts? Its not listed in any charts I can find and you can't go by bolt size that I'm away since its studs out of the body and your tightening the nut side of things...
I remember I couldn't find it anywhere also.
I made sure it was pretty snug with antiseize, but I believe I torqued it down to like 80 something...can't remember really, honestly.
You could just see what the crossmembers are torqued down at, and maybe give it a little more.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby DeeCee » Mon Feb 11, 2013 7:04 am
Actually found it after a little research on where the info is.
Toyota ST185 Repair Manual RM176U
Maintenance Section
Rear Suspension lower cross member to body mount bolts: 1280kg-cm / 93ft-lbs / 126Nm
Edit: RM305U1 USA/Canada has diff torque settings under maintenance:
(4WD Only) Rear Suspension lower cross member to body mount bolts: 9620kgf-cm / 117ft-lbs / 159Nm
DeeCee
