not a very good idea on a 4WD car... :|CMS-GT4":2azsf8ka said:F 18x8 +30 w/ 225/35-18 Toyo Proxes TR1
R 18x9 +15 w/245/35-18 " " " (...)
turbo4wd":2046j4yn said:Yeah those have been up there on the site for a while - one of the wheels has a nasty rash on one third of the lip..
pg":1x8ex28b said:http://www.1010tires.com/wheel.asp?wheelbrand=Kobe&wheelmodel=Ignite+%2D+Black
This is one of the styles that I liked but they only come in 17x7 40 offset.
Could I run these without spacers for now and if not what spacers will I need for the rear? Hopefuly it will be ok in the front without any. I'm thinking 215/40 tires
I have a stock suspension AT.
gt4rcdude":1frvclo8 said:pg":1frvclo8 said:http://www.1010tires.com/wheel.asp?wheelbrand=Kobe&wheelmodel=Ignite+%2D+Black
They'll work. 25mm H&R spacer in the rear.
pg":1raekc6u said:http://www.1010tires.com/wheel.asp?wheelbrand=Kobe&wheelmodel=Ignite+%2D+Black
turbo4wd":27a3rsn9 said:pg":27a3rsn9 said:http://www.1010tires.com/wheel.asp?wheelbrand=Kobe&wheelmodel=Ignite+%2D+Black
You wont need to run hub adapters at all. In either the front or rear.
With that said...
At that width / offset, you could run a 1" (or 24mm) hub adapter on BOTH the front and rear to make it look aggressive and you shouldn't encounter any rubbing issues, especially if you're at the stock ride height.
What kind of tolerances do you think he'll have between the backside of his rim and the suspension?
CMS-GT4":22gcx794 said:Some deep dish mesh wheels. I think there are other styles of mesh I prefer.
http://www.gtfour.ch/download/berichte/ ... 18/?bild=9
http://www.gtfour.ch/download/berichte/ ... 8/?bild=10
CMS-GT4":1b4ocz9e said:The sti guys are having a group buy for wide 5x100 wheels in good offsets. IE the rotor tourqes in 17x9 30et.
Here is the thread.
http://forums.nasioc.com/forums/showthr ... ?t=1381545
