The ST185 wheel size thread (offsets, widths, etc)
Re: The ST185 wheel size thread (offsets, widths, etc)
Postby CMS-GT4 » Tue Nov 11, 2014 3:58 pm
They will stick out in the front. 25mm spacer will make these equal to a 15et wheel.
Postby Twincam.22 » Tue Nov 11, 2014 4:35 pm
dam it, i need to find me a set of 5x100 so.
By any chance do you know what the distance is from hub face to wing and from hub face to strut?
Sorry if this is already commented on but there is 78 pages to go through to find out if it was asked before!
Twincam.22
Postby CMS-GT4 » Tue Nov 11, 2014 5:51 pm
Check out the first page where it shows the larger widths used. You can use their specs to do the math.
Postby Twincam.22 » Wed Nov 12, 2014 5:14 pm
sorted thanks :) might have found some nice 18" OZ supertourismo in 5x100 hopefully!
Twincam.22
Postby CMS-GT4 » Tue Nov 25, 2014 10:51 pm
What lightweight wheels would you buy with a $2000 budget. Preferably with the option to buy 5.
Postby 1337computing » Thu Jan 15, 2015 2:09 am
Alright I think I finally have my wheel spacing figured out and want to know if I'm correct.
I have 17" x 8" w/ +35 off set wheels on all fours with stock tire size 215/50/15. I want to put 15mm spacers on the front and 35mm on the back. From what I understand that would make the front +20 and the back +0.
Will this setup work? Will I have to roll the back fenders? Thank you!
1990 Celica All-Trac Turbo ST185
3" Berk DP, 3" Straight Piped, Magnecor Wires, EBC+
1337computing
Postby underscore » Thu Jan 15, 2015 2:39 am
How did you fit a 15" tire on a 17" rim?
Postby 1337computing » Thu Jan 15, 2015 3:35 pm
Just copied and pasted that part, I have 17" tires, whoops.
1337computing
Postby aus jd 2703 » Thu Jan 15, 2015 9:13 pm
CMS-GT4 wrote:What lightweight wheels would you buy with a $2000 budget. Preferably with the option to buy 5.
easy RPF-1 17 x 9, +35, 5x100.
2nd choice would work work 11R again 17x9, +17 rear +38 front 5x100.
but you are 5x114.3 so should have more options?
aus jd 2703
Postby Twincam.22 » Fri Jan 16, 2015 9:16 am
My new wheels! still have to get spacers but have BC coilovers ready aswell.
Twincam.22
Postby Mr Alltrac » Fri Jan 16, 2015 5:59 pm
Would 17x9 +35 rpf1 rims fit in the rear with a 20 mm spacer without having to roll the fenders?
1990 celica alltrac. Usdm wide body.
What kind of spacer would I need to run on a rota torque 17x9 +30?
Mr Alltrac
Postby Twincam.22 » Wed Feb 04, 2015 3:12 pm
With the wheels on.... its still a bit low on the back and needs a 20mm spacer i reckon but looking well...
Twincam.22
Postby Twincam.22 » Wed Feb 18, 2015 11:37 pm
Any pictures of 18x8 alloys with spacers on the back guys? Ifor some reason a lot of he image on here I can't view. . .
I'm thinking of a 35 to 40mm spacer on the back
Twincam.22
Postby CMS-GT4 » Thu Feb 19, 2015 12:21 am
You might have to google it. A lot of images were hosted by imageshack and they are now holding them ransom unless you want to buy a monthly account.
Postby Por2geezGT4 » Sun Mar 08, 2015 4:56 pm
What are the chances an 18x8.5 with a +22 offset wheel will fit all around?
Por2geezGT4
