The ST185 wheel size thread (offsets, widths, etc)
Postby CMS-GT4 » Tue Nov 29, 2005 4:39 am
I need pics from this angle, font and back. No need to lean a tire against the car. ;)
http://pg.photos.yahoo.com/ph/gtfour77/ ... pg&.src=ph
Then I need tire width, offset, amount lowered and tire size.
Try and get them as dead on as you can.
This may be best for someone who has muitiple sets of wheels around.
Perhaps a angle shot simular to the one in your sig will help too.
If I get time later this week, I will do something simular excewpt maybe use my 1" spacer in addtion to the wheel in the front to show an example of where the wheel will go with a certain offset.
It would be nice if someone with 18"s can help too. We can do a style version and a performance version.
Postby SuperWhite92 » Tue Nov 29, 2005 2:16 pm
http://therealjdm.com/archives/TheRealJDM01.pdf
A good article on wheel offsets and handling characteristics.
Shaun
SuperWhite92
Postby abraxxa » Wed Nov 30, 2005 9:13 am
I can only supply pictures of my suspension-stock ST205.
I'm looking for 18" Gram Lights 57F-Pro but I can't find a dealer in Austria who is able to deliver them :x
facelift ST205
abraxxa
Postby Toxygene » Fri Dec 09, 2005 9:13 am
I went to Toyo for their tire suggestion and it seems to be right on with what everyone is saying:
http://fitments.toyo.com/guide/search.php?model_year=1990&make_id=55&model=Celica&vehicle_id=21769&plus_size=+2
Oh and how well do wheels off of the latest Celica fit on an Alltrac. I'm curious because I am thinking of getting TTE wheels as my daily driver wheels:
http://www.tte.de/popup/cm_celica_wheels.htm
Toxygene
Postby furpo » Fri Dec 09, 2005 10:28 pm
it may help to measure the wheels as different companies size them differently.
here are links to my narrow body gt4 with 16 x 7 advanti mags. they measure 7 inches wide (inside to inside) or 7 1/2 inches (outside to outside). the offset is 40mm.
http://www.alltrac.net/phpBB2/viewtopic ... hlight=gt4
http://www.alltrac.net/phpBB2/viewtopic ... c&start=15
here is a link to the same car with 17 x 8 oz superleggra's. they measure 17 x 8 1/2 (inside to inside) and 17 x 9 (outside to outside). the offset is 35mm.
http://www.alltrac.net/phpBB2/viewtopic ... highlight=
another interesting thing to note is that on the front one wheel sits in a different position to the other. i found out when doing a wheel allignment this is due to the huge factory tolarance in allignment settings.
roger
furpo
Postby CMS-GT4 » Wed Mar 08, 2006 4:42 pm
I think I may have found more wheel options. The are not that cheap though.
http://www.autornd.com/catalog/product_ ... da96eb7f8c
Postby BlackGT4 » Thu Mar 09, 2006 6:42 am
I am looking at ordering a set of Simmons 3 piece wheels.
I spoke with the guys at the shop, and was told that I can order them in any offset, etc..
as i am after dished wheels, he mentioned that coz of the brake setup i dont have much options. so i am pretty much confused how that red car has massive dish on the first page of this thread.
i then asked about the possibility of using spacers so the brake wouldnt intefere with the rim.. he then realised how desperate i was for dish and booked me in for next week to try out some different sizes and stuff.
hopefully this goes good.
at the moment i'm thinking 16x8s with spacers will work..
but we will be trying it all out next tuesday i will let you all know how things pan out.
BlackGT4
Postby SuperWhite92 » Mon Mar 13, 2006 2:40 pm
Keep in mind that the 17x9's want a 10-15mm spacer in front, and a 25mm in back. This makes the effective specs on those wheels like this:
Front: 17x9, +25ET
Rear: 17x9, +13ET
You can use those specs to match other wheels of other widths and offsets to the fender. This setup allows vitually no room to go out or in with it, so make sure your new wheel doesn't extend much, if at all, further in either direction.
Shaun
SuperWhite92
Postby Akira-R » Tue Jun 20, 2006 2:52 am
Found this site with some wheels 17x8 +35 that should fit, and they are only 18 lbs and on sale for under $100 a rim
Akira-R
Postby Akira-R » Tue Jun 20, 2006 5:13 pm
SuperWhite92 wrote:
Akira-R wrote:Found this site with some wheels 17x8 +35 that should fit, and they are only 18 lbs and on sale for under $100 a rim
Maybe a link?
heh, i must've been sleep-posting =p
http://edgeracing.com/wheels/flik/
Akira-R
Postby justjoe » Wed Jul 26, 2006 9:40 pm
Anyone have Factory 185 wheel weights?
justjoe
89 AW11 MR2 Hardtop SC Swap <-- w00t!
90 ST185 Celica All-Trac
99 Camry Grocery getter..
justjoe
Postby CMS-GT4 » Mon Nov 13, 2006 7:03 pm
Sportmax wheels. 17x9 38et 255/40/17
http://alltrac.net/phpBB2/viewtopic.php ... &start=225
Postby db » Mon Nov 13, 2006 7:58 pm
justjoe wrote:Anyone have Factory 185 wheel weights?
With 215/50/15 Dunlops, they weighed 42+/- pounds on my bathroom scale.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby CMS-GT4 » Sun Feb 25, 2007 5:52 pm
Here is a nice new tire calculator.
http://www.wheelsmaster.com/rt_specs.jsp
Postby Meurz » Wed Feb 28, 2007 10:42 pm
Others I use a lot:
To compare offsets:
http://marksink.com/tire_wheel_offset/offset.html
And for tire sizes:
http://www.miata.net/garage/tirecalc.html
Turbocelica.nl
Meurz
