parking-brake shoes
Postby BLOWNTACO » Tue Apr 08, 2008 7:38 pm
They're pretty easy to replace. Loosen the adjuster to help release the rotor. Once you get the rotor off (assuming that the caliper is off), its pretty easy to decifer. Backing plate stay in place, just be careful about the tension springs. Go to the local Toyota dealership and get a parts diagram on how everything goes, and go by the auto parts store to get a brake button spring tool. Then from there its a piece of cake!
A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government.
-Thomas Jefferson
BLOWNTACO
Postby bridge47 » Thu Apr 10, 2008 1:18 am
After abusing inadequate E brakes to get the rear to come around on various cars I always thought it would be worth it to try and find/fab the calipers that can allow you to hook up your cable for full rear brake power. Can anyone shed light on this?
bridge47
Postby WarTowels » Thu Jun 12, 2008 4:33 pm
It's been done. Not sure specifically on the alltrac, but basically what you need to do is find a car that has caliper e-brakes and then adapt the system.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby gpmarzan » Sat Feb 07, 2009 11:04 am
WarTowels wrote:^ When I called Toyota direct those part numbers didn't work?
These ones did though:
1 - 46550-33010
1 - 46590-33010
2 - 46540-33010
-Towels
Sorry to revive this issue, but I wasnt clear if the part #s listed here are for both st165 and st185?? I am trying to order a few parts for my trac and this is one of em. Doing them quick before my wife finds other things to spend my money on. :P :twisted:
Patrick M.
st165
gpmarzan
Postby WarTowels » Sun Feb 08, 2009 3:42 am
No clue.
Try the EPC, or the online EPC.
Or call Toyota and ask, they can look it up.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby aubeone » Wed May 13, 2009 4:09 pm
This is perfect! After pulling my rear brakes apart to swap in new rotors, pads, and lines I found that the e-brake set-up all came out in tiny little bits...so now I'm in the process of sourcing the replacement...EVERYTHING lol
I'm in Canada, soif the shop names sound strange that's why, but I tried CarQuest, Benson Auto Parts, and Canadian Tire without result. I then called the dealer in my area and the shoes are $51 EACH...???
Hopefully 1stToytoaParts.com ships this far north :/ Anyone know for sure?
Parting Out an 88 ST165
Parts Available:
JDM Gen2 3SGTE w/ converted harness and Gen2 ECU
New suspension and brakes
Full Black Leather Interior (both front seats with pwr lumbar)
Contact for details.
aubeone
Postby aubeone » Wed May 20, 2009 5:26 pm
I am soooooooo excited!
But first, I need to know if the gt/gts parking brake parts are the same as the alltrac...anyone know for certain?
If not, I'll have to find out the old fashion way...by taking in what's left of my 21 year old stuff and comparing it to the stuff a semi-local parts shop has INSTOCK...
The best part is the cost. The Shoes they have, assuming they are the correct ones, are $28 for the SET, and the hardwar is $32 for the SET. Not per side, not per part, the entire set will cost $60 CDN...
I think I just pee'd a little...
Parts Available:
aubeone
Postby aubeone » Wed May 20, 2009 11:47 pm
As an update, the first thing I did when I got home from work (after eating) was to check on the part numbers (parking brake parts) between the st165 and liftback gts...and they're identical!
Parts Available:
aubeone
Postby gpmarzan » Thu May 21, 2009 12:24 am
aubeone wrote:As an update, the first thing I did when I got home from work (after eating) was to check on the part numbers (parking brake parts) between the st165 and liftback gts...and they're identical!
so shoes for the gts will work, huh. Advanceauto has shoes for the gts for around 30 bucks
edit: it also shows for the alltrac.
Patrick M.
st165
gpmarzan
Postby aubeone » Fri May 22, 2009 12:01 pm
Confused about the last part...what also shows for the alltrac?
Parts Available:
aubeone
Postby Rick89GTS » Fri May 22, 2009 3:09 pm
This is great info to know. Thanks. Let us know when you get it all installed.
Rick89GTS
Postby esracing » Fri May 22, 2009 4:01 pm
ok fyi i have a 165 and orderd pbs and got them they were wrong ,i told him it has abs , we had to order none abs shoes , the diff was the pivit pin hole at the top was larger on the 1st set the rite one are smaller hole
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby aubeone » Fri May 22, 2009 4:17 pm
I'm just keeping my fingers crossed that everything matches up...i'll keep you posted with my progress.
Parts Available:
aubeone
Postby aubeone » Sat May 23, 2009 8:55 pm
The parts I found locally are identical to the parts that came off my car! I have already swapped the pins over to return the shoes for a $20 core...Pics of the part will be up soon :D
Here are the Part Numbers;
Part Supplier Part Number Cost
Shoe Set (Yes, all four) Absco A859 $27.86
Hardware Kit (Complete) Carlson 17390 $31.33
Incase you have a hard time finding a local supplier or shop that deals with Absco or Carlson, here is the contact information for the shop that I got mine through.
Peterborough Automotive
Chris or Randy
Peterborough, Ontario, Canada
(705) 742-2446
Parts Available:
aubeone
Postby aubeone » Sun May 24, 2009 5:54 pm
I took a few pictures comparing the Parking Brake Shoes that came off the car with the new ones. By the time I got the camera out I had already swapped the pin...
Parts Available:
aubeone
