Oem torsen LSD test (Need volunteers)
Postby Simba » Sat Feb 24, 2007 2:39 pm
Actually, that brings up another fairly easy method to check without popping the case open: Rent or borrow a borescope and stuff it in the drain or fill hole.
Lots of fast, loud things.
Simba
Postby TomsGT4 » Fri Mar 02, 2007 11:19 pm
bridge47 wrote:Easy enough, I once removed my diff plug and using a bright flashlight was able to see the spider gears on my open diff 93.
I believe the Torsen has helical gears that should be visible as well. You
have to jack up the rear of car and do a little wheel turning to get a good look.
Ha ha anyone need to change their rear diff fluid?
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby CMS-GT4 » Sat Mar 17, 2007 4:50 pm
I just did my test. Am I to assume I have a clutch type lsd or a torsen?
When I turn the driveshaft both wheels spin the same way. And when I give resistance the turn the same way.
It is possible, that I have a torsen, cause my rear brakes are sort of sticking giving my rear wheels some resistance.
Either way, when I turn the driveshaft, both wheels turn in the same direction.
BTW: my door has this code.
-737/E150F = 5 speed manual with viscous coupling LSD.
I might not be completely convinced so I may need to look with a scope inside the diff housing or see if I can see the gears through the hole.
Postby CMS-GT4 » Thu Mar 29, 2007 4:59 pm
I drained the rear diff fluid and tried looking inside. I could see one gear, but am unsure what the gear is.
I might have to rent a scope or something to get a better view. Can you even see the helical gears from the drain plug or are they further in?
here is a pic of the plug for reference.
Postby CMS-GT4 » Thu Mar 29, 2007 6:29 pm
After looking at some photos I do not think you can see the torsen gears through the drain. See pic:
I am going to try and find another light that fits in the drain and try again though.
http://img27.imageshack.us/img27/6000/dsc000340ls.jpg
Postby bridge47 » Fri Mar 30, 2007 8:08 am
Gears are visible at the fill hole. Use a small mirror (telescoping ones work best) and bright flashlight. Borescope not required unless you have access to one.
bridge47
Postby CMS-GT4 » Fri Mar 30, 2007 1:58 pm
Could not get a scope, but I bought a better flash light. its an open diff.
So I will be keeping my lsd. I need to see if toyota has a lsd install kit with all the clips etc...
Postby Cody Mamak » Sat Mar 31, 2007 7:32 pm
Uhm...
SO, what if my car plate says:
model st185L-BLMVZG
c/tr/a/tm 202 GS10 - 767 E151F
chassis no. is JT164STJ500011860
Do I have a open or a TorSen??
:shrug:
Cody Mamak
Postby etantshi » Sat Mar 31, 2007 9:44 pm
According to the code and previous information posted it should be a torsen, unlike mine. No plate, just a sticker: 737/E150F
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby RedCelicaTRD » Sat Mar 31, 2007 11:11 pm
EPC says it should be an LSD....
Postby eddie_gt4 » Mon Apr 02, 2007 5:34 am
Cody Mamak wrote:(...)Do I have a open or a TorSen??
:shrug:
yes, you have a Torsen and a stronger gearbox (that was used in ST185 CS too :D )
p.s. Conan, another one pre-02-1992 EDM ST185 that was equiped with a E151F gearbox :twisted:
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby coyoteboy » Mon Apr 16, 2007 10:12 am
I'm a 150F 767, UK original car, and I believe all UK cars came with LSD and CS box? Although it now has a 205 box in it.
coyoteboy
Postby lumbercis » Mon Apr 16, 2007 7:02 pm
I don't think any USDM cars got a Torsen "on purpose" else the BGB would list information about them as it does for the open diffs. There may be a few cars that ended up with them by chance. Maybe they were originally destined for a different market, then a few orders from the U.S. came in, or maybe they ran out of open diffs, had a few extra torsens laying around, etc. Or maybe just a simple mistake since the exterior casings are pretty much identical. In any case, if you have a USDM car, I wouldn't get your hopes up about having a torsen, in all likelihood, the few that have them are flukes.
J.
lumbercis
Postby CMS-GT4 » Mon Apr 16, 2007 7:04 pm
It was a dealer option. So, I think they were open standard, and its random if the new owner opted for the lsd or not.
Postby Corey » Mon Apr 16, 2007 7:47 pm
So im assuming Torsen is better?
Corey
Images: 50
