Active member
Any specs Rip?
Wilwood referred me to colemanracing.com to look into custom rotors.
I can use a wilwood hat and use their rotors. The only downfall is they are not as cheap. I would pay around 134.25 for each rotor ring.
From my guestimation the rotor ring needs to be 307mm diameter and ~7" inner diameter to have full pad contact.
Edit: I just took out my wore down pads. It looks like the pad surface height is just over 2.25".
I bet if I did enough research I could find something off the shelf as well.
