ST205 Front Brakes
Postby bozo-merlin » Fri Apr 20, 2007 7:19 am
swap 185 brake for 205 is not only for the caliper
bigger disc are usefull too
why use a braket when drill a bigger hole in the caliper make them fit ?
for the MC, 185 and 205 are both 15/16", same lenght, same mount, no reason to change
but 185 ABS don't really like the new brake setting (if you have one, try to "unfuse" it)
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby eddie_gt4 » Fri Apr 20, 2007 7:36 am
bozo-merlin wrote:swap 185 brake for 205 is not only for the caliper
that's for sure! :D
btw, correct me if I'm wrong, but I don't think that ST205 front calipers (and brake pads) can be used with ST185 front brake discs (aren't they too small?)
bozo-merlin wrote:why use a braket when drill a bigger hole in the caliper make them fit ?
any pic?
bozo-merlin wrote:but 185 ABS don't really like the new brake setting (if you have one, try to "unfuse" it)
you don't have ST205 brakes in your car, do you?
in pics with your car I see ST185 OEM front caliper :shrug:
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby bozo-merlin » Fri Apr 20, 2007 11:37 am
I don't think 185 disc goes with 205 caliper because off the offset disc itself
I have the 205 complete brake kit to install on my 185 (no picture yet but will give solidworks part plan when complete)
rear are bolt on, every knows
front disc need approx 4.8mm spacerbetween disc and hub to clear the hub, we need a 4/10 mm metal rubber to modify the bore of the hub to center correctly disc and wheel
All that is done for me, i will work on the braket to fit the 205 disc with 4.8mm spacer inside and the 315x28mm disc
We are use to see S14 with 300ZX TT disc here in Europe, i am sure i could the same with 205 brake on 185
i will finish my rear drive train the 1st of may (205 LSD, polybush superflex from FENSPORT, D2, crossmember and diff bush kit from Mario, ARB from WHITELINE, ARB link from TWOSRUS, fuel cell from SUMMIT, new full avia brake and fuel hose) then i will start the front drive train and share you some informations
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby eddie_gt4 » Fri Apr 20, 2007 12:00 pm
another one sticky thread to come :D
eddie_gt4
Images: 11
Postby abraxxa » Fri Apr 20, 2007 7:34 pm
Look at the the brake swap of user666:
http://www.gtfour.ch/forum/thread.php?threadid=1657&sid=
facelift ST205
abraxxa
Postby bozo-merlin » Sat Apr 21, 2007 8:33 pm
abraxxa wrote:Look at the the brake swap of user666:
That's what i think to do, but what brake disc are used ? i mean why having a double PCD (looks 5x100 and 5x120 like BMW or 5x114.3 like supra)
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby SuperWhite92 » Sun Apr 22, 2007 6:31 pm
To mount the calipers on the 185, according to my measurements, using the full size ST205 318x32mm disc, you will need to space the rotor outwards 4mm to clear the ball joint, you will need to space the caliper 1mm outwards to center the caliper on the disc, and you will need to move the mounting points 18mm outwards to sit the caliper where it needs to be for the st205 disc.
Shaun
SuperWhite92
Postby abraxxa » Sun Apr 22, 2007 10:16 pm
I asked him for the discs, just check the thread again for a reply.
facelift ST205
abraxxa
Postby eddie_gt4 » Mon Apr 23, 2007 12:56 pm
SuperWhite92 wrote:using the full size ST205 318x32mm disc
aren't they 315mm? :)
eddie_gt4
Images: 11
Postby ST185pinjo » Mon Apr 23, 2007 1:08 pm
http://homepage.ntlworld.com/r1biker/20 ... st185.html
This is one way to do it. You will need a bracket if you want to use the full 315[mm] of the ST205 disc.
I have my front set painted and waiting to go on. Need some new cilinders and rubbers too.
ST185pinjo
Postby Gary ST165 » Wed Apr 25, 2007 12:23 pm
ST165 turbo 4WD
Gary ST165
Postby bozo-merlin » Wed Apr 25, 2007 2:08 pm
Why nobody want to keep the 315mm diameter ?!?
thanks Gary ST165 for the link
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby bozo-merlin » Wed Sep 05, 2007 4:35 pm
http://www.gtfour.ch/forum/thread.php?threadid=865&sid=
i finally go that way but with ST205 full size rotors, 5mm rotor to hub spacer
my prototype will be ready next wednesday, if it's work i will give you the draw of the braket and the way to mod the caliper
i do that way only because i need the car running the 09/15 to practice the 09/30, but with more time, i would look for some 330x30 rotors, with that size we have more facilities to draw a braket without mod the caliper and 330x30 or 32 are hummm : 8)
i have easy to find another front set of 205 caliper to do the next step (330x30/32) but you guy are so far, sell my full front mod would be too much in shipping to US countries :oops:
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby etantshi » Thu Sep 20, 2007 11:33 pm
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby etantshi » Thu Sep 27, 2007 11:00 pm
Well I just picked these up. Might be time for me to do a write up.
http://www.alltrac.net/phpBB2/viewtopic ... 828#217828
André B.
etantshi
