ST205 Front Brakes
Re: ST205 Front Brakes
Postby alltracshoak » Fri Mar 26, 2010 12:16 am
yes let me know how much you charge that way i can decide to purchase a set of 205 brake
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby CMS-GT4 » Fri Mar 26, 2010 12:57 am
klue wrote:Dont worry, either way I can help you fit the 205 rotor if thats what you choose.
The kit im working on will not require a modded caliper or have any balljoint issues.
You may want to offer a bracket that compensates for those who shaved their calipers to use the 205 rotors as well.
Postby darthripley » Fri Mar 26, 2010 2:15 am
even tho we already fitted the 205 calipers & rotors on i would still be interested in a kit.
good work making this for us all klue!
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby klue » Fri Mar 26, 2010 2:26 am
I appreciate everyone's opinions!
It is taking some time. I should have another update Saturday as I go to the shop to work on the second spacer.
To fit the st205 brake rotor you have to remove some material from the caliper. I was strongly against this at first
but it seems the best way from a price stand point. The way to fit the 205 brake needs the caliper to be trimmed to have the rotor properly fit between the pads, I reluctantly accepted this after the machinist convinced me it would not affect the integrity of the calipers' mounting.
The second method is more Taylor to my tastes, but surely is a large market for others.
kit will have
-3spacers; hub ring, pad spacer, and rotor spacer
-may require longer wheel studs( i will source these for the kit)
-will require ZERO modification to the caliper(if you have shaved 1-2mm we can include a washer)
-may or may not need a longer brake line, i have not tested to see how this mocks up.
-no bracket, no ball joint issue
-should fit 16inch wheels
Postby CMS-GT4 » Fri Mar 26, 2010 6:52 pm
darthripley wrote:even tho we already fitted the 205 calipers & rotors on i would still be interested in a kit.
I was thinking about this. I think those who have shave their caliper ears can run a larger rotor spacer to compensate. I guess that really depends on how large the kits current rotor spacer is. Then again maybe a 1mm-2mm spacer could be used behind the bracket to move the caliper to the stock offset. Hrm.
Postby CMS-GT4 » Fri Mar 26, 2010 7:46 pm
klue wrote:I appreciate everyone's opinions!
kit will have
Couple of questions:
1) What is the second bolt pattern on the rotor? Might be useful for those considering the 5x114 conversion.
2) What is the spacer size. You might be able to sell the spacer to those who want to do the regular 205 rotor conversion.
This link suggests a 4mm spacer for the 205 rotor. I was looking at some for about $25 on ebay, but I would still need to machine them down from 7" to 5" to fit inside the rotor bell.
http://homepage.ntlworld.com/r1biker/20 ... st185.html
Postby klue » Fri Mar 26, 2010 8:19 pm
rotors are 5x114.
I cant deliver and spacers sizes atm. We made the spacer extra thick so that we just shave it down as we need.
Postby CMS-GT4 » Sun Apr 04, 2010 4:34 pm
I see. Another question, if you offer a 205 rotor replacement will you be offering them milled down? I have still kicked around going with the 205 rotor route. So if the 205 rotor price is right, and I won't have to worry about sourcing a machinist everytime I do brakes, it may still be an option for me.
Postby klue » Sun Apr 04, 2010 5:20 pm
Everything will be done in house.
st205 rotor milling and the secondary rotor will be machined by us as well
Postby CMS-GT4 » Sat Aug 21, 2010 6:44 pm
Hey bozo-merlin, what kind of price would the caliper bracket cost? I might have a local solution for 330mm rotors.
Postby MWP » Mon Feb 21, 2011 5:11 am
Dragging this up again, as im going through it at the moment.
Ive made up 3D models of the 205 claiper, 185 strut and my wheels to work out what can be done.
And.... my wheels suck :(
No where near enough spoke clearance for the caliper.
Postby CMS-GT4 » Mon Feb 21, 2011 4:23 pm
Nice modeling. Is the rotor design custom, or is it based off of a modified 205 rotor?
Postby MWP » Tue Feb 22, 2011 1:01 am
Thanks, but what rotor?
There isnt one in that model.
Postby CMS-GT4 » Tue Feb 22, 2011 1:08 am
Is that disc supposed to be where your spokes are? I thought that was the rotor.
Postby MWP » Tue Feb 22, 2011 1:24 am
The bid grey solid disc thing is the spokes of the wheel :(
