ST205 Front Brakes
Re: ST205 Front Brakes
Postby klue » Tue Feb 22, 2011 3:43 am
I forgot about this thread. Having switched to willwood set up I never bothered to try the 16 inch set up I had made. It stands completed and collecting dust in my basement. Not sure If I had put these pics up, but here it is complete.
Thats the caliper/rotor in a gen 7 gts wheel. fits perfectly.
Some nice modeling there MWP
Postby tubasteve » Sat Mar 03, 2012 4:59 am
another year later another dead.......what happened klue?
tubasteve
Postby klue » Sat Mar 03, 2012 4:42 pm
Like I said in the last post, one side of the kit is finished, everything mounts up and appears to work. But I have no reason to finish it as Im using willwood stuff on my car now. If someone was interested I could finish it up but until then it will stay in the pile of many doomed projects
Postby tubasteve » Sat Mar 03, 2012 6:10 pm
Friend of mine is possibly. He should be buying his*first alltrac* this week, you have calipers add well? he hates the brakes
-jr
tubasteve
Postby klue » Sun Mar 04, 2012 4:40 pm
Yes Ive got a full set of front hubs
Let me know what he thinks and we can work out something
Postby tubasteve » Sun Mar 04, 2012 5:10 pm
I will this week.
Jr
tubasteve
Re:
Postby tubasteve » Mon Mar 05, 2012 5:11 am
bozo-merlin wrote:OEM
Made by Bozo® :lol:
330x32, unmodded caliper, cheap part remplacement
funny, he flipped the picture from the other side to look like the same side, i was looking for tire size rofl.
tubasteve
Re: Re:
Postby bozo-merlin » Mon May 21, 2012 8:41 pm
tubasteve wrote:funny, he flipped the picture from the other side to look like the same side, i was looking for tire size rofl.
You're right, i installed it only 1 side as my camera can shadow pics (to get near the same pics)
You won a drink if you come :lol:
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby aus jd 2703 » Sun Jul 22, 2012 10:26 pm
has any one found a way to mount the full size 205 disc on a 185?
im fine with custom rotors.
aus jd 2703
Postby MrMcQuacker » Sun Aug 19, 2012 6:59 am
Any Updates people? I would really really love to have the 205 calipers on my 165.
MrMcQuacker
Postby CMS-GT4 » Sun Aug 19, 2012 12:20 pm
There are a dozen options, its just a matter of the work you want to do. IS300 rotors redrilled seem to be one of the easier methods. There is also the wrx rotor method, but you do ont get the advantage of the cooling of thicker rotors plus you have to use pads on the spacers. Its all just boils down to what kind of work do you want to do to make rotors work for your setup. There was also a cadillac catera rotor I think the 6th gen guys used.
Postby soarer.jzz30 » Mon Apr 29, 2013 6:39 am
not to sound completely ignorant here. But, why would it be so hard to simply switch out some portions of the front 205 suspension components in order to completely remove the need to custom work anything? They are nearly identical cars, is the suspension geometry that significantly different that one couldn't simply swap out spindles, or front strut and hub assembly. I mean some portion would seem like it could bolt up and work. Seems a bit excessive... But so does all this custom work... overnight from japan!!
:crazy:
soarer.jzz30
Postby MWP » Mon Apr 29, 2013 8:04 am
Damn why didn't we think if that before??? :cry: :P
Have you ever looked at 205 front suspension?
It's super-strut. It won't bolt into a 185 and making it fit will be far more more difficult than adapting just the calipers.
Most 205 race cars have actually been converted to macpherson strut (185 style) suspension as it has less parts, and is easier to tune.
Postby aus jd 2703 » Mon Apr 29, 2013 8:27 am
What hubs etc do the 205's use? I swear I have raced 204's with the 4 pot brakes so i wonder if a 204 hub would fit 205 brakes and 185 arms??
aus jd 2703
Postby phattyduck » Mon Apr 29, 2013 3:56 pm
aus jd 2703 wrote:What hubs etc do the 205's use? I swear I have raced 204's with the 4 pot brakes so i wonder if a 204 hub would fit 205 brakes and 185 arms??
Those ST204's were probably running the ST205 calipers with ST205 disks that have been machined down in diameter. The caliper mounting points between the SuperStrut and standard strut hubs are just a bit different.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
