ST205 Front Brakes
Postby CMS-GT4 » Mon Oct 01, 2007 2:01 pm
Has anyone looked into what needs to be done to powder coat a caliper? For some reason baking calipers @ 400 degrees sounds bad to me.
I think painting would be better over PC.
Postby GT4RC » Mon Oct 01, 2007 7:00 pm
What temp do your calipers get under some hard braking? will powder coat hold up?
GT4RC
Postby illGT4 » Mon Oct 01, 2007 9:40 pm
bozo-merlin wrote:my new braket are ready, just try them and then ...
update? :D
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby bozo-merlin » Tue Oct 02, 2007 7:01 am
illGT4 wrote:update? :D
That was yesterday ...
Bolt on now, but need to sort out an engine issue and then could test them for what i made them for : track day ;)
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby illGT4 » Tue Oct 02, 2007 3:02 pm
Yep, It was yesterday. I'm hoping you work as fast as you talk. :)
I'll be interested to see how they hold up to your "track day". 8)
illGT4
Postby etantshi » Fri Oct 05, 2007 5:15 am
GT4RC wrote:What temp do your calipers get under some hard braking? will powder coat hold up?
I would think so. I had my exhaust manifold heat shield PCed and it held up to the temps of the turbo.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby abraxxa » Fri Oct 05, 2007 7:17 pm
PAINT!
this one:
facelift ST205
abraxxa
Postby etantshi » Fri Oct 05, 2007 8:31 pm
I've PCed many a caliper. No ill effects. No problems.
André B.
etantshi
Postby tybrinturbo » Wed Jan 30, 2008 9:11 pm
i can put st205 brake setup with rally wheel in 15inch?
st185cs rally car
st205 wrc
audi rs6 2004
tybrinturbo
Postby Meurz » Wed Jan 30, 2008 10:52 pm
No. 16" is the smallest which still fits over ST205 brakes, like the stock ST205 wheels.
Turbocelica.nl
Meurz
Postby SuperWhite92 » Wed Jan 30, 2008 11:46 pm
Meurz wrote:No. 16" is the smallest which still fits over ST205 brakes, like the stock ST205 wheels.
And to clarify, a lot of 16" wheels don't fit. You have to have a good wheel.
SSR Comp/Type-C's barely clear. 7th Gen rims don't. 16x8 +38 Enkei RP01's do Be careful what you buy if you're shooting for 16's
Shaun
SuperWhite92
Postby sleeper » Fri Feb 01, 2008 7:04 am
16" speedlines does also fitt.. ( but only with about 3mm clearance..)
sleeper
Postby etantshi » Fri May 02, 2008 5:22 pm
Well since no one is going to provide measurements... I'll be doing some tonite and hopefully cutting them monday. Trial and error time.
André B.
etantshi
Postby darthripley » Fri May 02, 2008 11:21 pm
etantshi wrote:Well since no one is going to provide measurements... I'll be doing some tonite and hopefully cutting them monday. Trial and error time.
YAY!!! :D
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby etantshi » Sat May 03, 2008 5:20 am
Calipers are so close they almost fit. Almost too close for a bracket...
André B.
etantshi
