polyurethane bushing drawbacks
Postby Bill Strong » Sun Jul 27, 2008 8:29 pm
where does one get those white delrin bushings for the subframe?
Bill Strong
Owner - The MR2 Owners Club Message Board
www.mr2oc.com | www.v8mr2.com | www.racingstrong.com
1988 Celica All-Trac | 1991 MR2 | 1986 MR2 | 1986 V8 MR2 | 1985 ITB MR2
Bill Strong
Postby Gary ST165 » Sun Jul 27, 2008 8:38 pm
ST165 turbo 4WD
Gary ST165
Postby turbo4wd » Mon Jul 28, 2008 2:16 am
___Scott___ wrote:I should also clarify that I did replace the spherical bearings when I put in the rest of the poly bushings. In fact, I'm the guy who pioneered the replacement of those spherical bearings. Prior to my write-up here, people were replacing the whole carrier assembly in order to get those spherical bearings.
So, yeah, I'm not advocating putting poly in place of those spherical bearings, only in place of the OEM rubber bushings.
Scott, your writeup showing that it was possible to "press" out the bearings with the puller was great.. Anyone can go to a local Autozone, rent one of these badboys and switch out all of their bushings..
And Bill, when you place an order with Mario, it'll take about 2 weeks to receive since they're shipping from Austria.
Once you get the subframe down, a screwdriver and a 3lb sledge is all it took to take all the bushings out.. Might want to think about giving the entire assembly a good degrease/wash and then spraying it with an anti-rust enamel.. like por-15 or plasti-kote.
Dan
Undercover Moderator
turbo4wd
Postby gpmarzan » Fri Aug 01, 2008 2:42 pm
Will I need to take out all the bolts that connects the control/trailing arms to the hub to have access to the spherical bearings? I tried just taking out the bolt on the control arm #2 and tried lifting up the control arm but a bolt on the back of the hub is preventing it to lift all the way. I would really want to replace 1 of the the four spherical bushings before my trip back to nj w/out having to take the other ones apart- if possible. Any suggestions?
Patrick M.
st165
gpmarzan
Postby ___Scott___ » Sat Aug 02, 2008 3:17 am
In this pic: Image
notice that the rear arm is between the puller and caliper, the trailing arm is not shown but is just hanging, while the front arm is still attached in its normal position.
That worked on both sides for the rear spherical bearing. I didn't get pics of the front bearing and I don't remember specifically how I did it but I do know that I didn't remove the arms completely.
It's quite likely that I used a prybar to help wedge the arm up out of the way.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby gpmarzan » Sat Aug 02, 2008 10:45 pm
I actually just got done replace one of the rear spherical bearing about an hr ago. Took about 2-3hrs of actual work time to get it done. The hardest part was putting the new one back in. I did not have to take anything else off besides the wheel and that one bolt for the bearing in case anyone is wondering.
Patrick M.
st165
gpmarzan
Re: polyurethane bushing drawbacks
Postby aus jd 2703 » Fri Mar 11, 2011 1:38 am
ok bringing this back from the dead cause well i can :D.
i currently want to replace every bushing in my car starting with suspension then diff finally engine mounts now i get the logic behing using stock sphericals for arm links 1 and 2 in the rear but here is my question, for the rest of the rear and front suspension is poly ideal?
is there any where a complete list of all bushings on the car?
my cars is dd with weekend racing (soon i hope) so far its all tarmac. so my plan is as follow:
stock links 1 and 2 in the rear.
poly front inner and poly sway bar links and mounts.
im going to tein ha's so ignore strut tops etc.
what other bushing do i need? also oem or poly?
cheers guys trying to get my head around whats ideal for my situation
aus jd 2703
Postby lumbercis » Tue Jun 21, 2011 2:41 am
Another bump!
VERY interesting thread on this topic over on mr2oc from some competitive autocross folks...
http://www.mr2oc.com/showthread.php?t=414661
Question raised from that thread: which bushings in our suspension are multi-axis bushings? (and thus, possibly not a good place to use poly)
J
Caldina powered...
lumbercis
Postby Corey Darling » Mon Apr 02, 2012 10:00 pm
I'm looking at toyodiy and I can't seem to find the diagrams for the spherical bearings in the knuckle.
Just to confirm - do new knuckles come with the bearings pressed in?
Thanks
Corey Darling
Images: 50
Postby MWP » Tue Apr 03, 2012 5:38 am
Corey Darling wrote:Just to confirm - do new knuckles come with the bearings pressed in?
They do.
Some smart guy worked out that a model of Supra uses the same bearing, and can be supplied separate (it has a part number).
Re:
Postby RafaCalde » Tue Apr 03, 2012 3:10 pm
___Scott___ wrote:In this pic: Image
The one SuperPro bushing you have on the rear carrier, which on is that called?
Rafa
RafaCalde
Postby Gary ST165 » Tue Apr 03, 2012 5:46 pm
the purple bushing in that picture is ^^^ the rear trailing arm
http://www.fensport.co.uk/Parts/Model_1 ... ory_2/1715
ST165 turbo 4WD
Gary ST165
Postby aus jd 2703 » Tue Jul 10, 2012 12:18 am
ok so each side has 6 bushings 3 inner and 3 outter...
which 2 (one side) do you replace with the toyota spherical bushings?
i know the trailing arm can be all poly. so there goes 2 out of the six for each side.
so of the four remaining bushings in the radius arms, which are poly and which are OEM?
would it be safe to assume the hub (out board) bushings are poly and the cradle/inboard are the OEM spherical?
aus jd 2703
Postby YerRandO » Sun Jul 15, 2012 5:44 am
aus jd 2703 wrote:would it be safe to assume the hub (out board) bushings are poly and the cradle/inboard are the OEM spherical?
The spherical bearings are on the hub side
1990 Alltrac -white: Restoration phase
1994 GTS -black: Sold
-James
YerRandO
