[HOW TO] remove struts, AGX mr2, rear strut conversion
Re: [HOW TO] remove struts, AGX mr2, rear strut conversion
Postby 88gt4DE » Thu Apr 24, 2014 5:30 pm
Killtodie wrote:Any reason why 4 fronts are used, and not 4 rear, as the rear struts would be more applicable from an MR2
Not sure ... I used the same in the rear cause I had an extra set and figured if I didn't like it I would change it. and I actually Love the look and the ride. Its perfect ...
Postby Killtodie » Sat Apr 26, 2014 1:39 am
Hmm, because the front of an MR2 is lighter than the rear of the All-Trac. I figure the extra weight upfront (the huge trans) and the extra weight in the rear (rear diff) would be better off using rear MR2 struts all around.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby tw2 » Sun Apr 27, 2014 5:11 am
The reason was that there was confusion whether the rears actually could be used. There was talk that they might not be replaceable inserts and no one wanted to order a set to see (I presume this has been proven now). The other reason was that the inserts were generally considered very harsh for the mr2 so they were expected to be much harsher than stock but liveable for daily driving on the alltrac which I think they definitely were. I never had the mr2 rears to compare to but I would definitely do it all again, they were prefect in my opinion.
Thomas, JDM 90 185, 06 350z
tw2
Postby Killtodie » Sun Apr 27, 2014 7:03 pm
What do you mean by "not be replaceable inserts"?
I believe the rears are shorter though. but not finding any info on that.
Killtodie
Postby tw2 » Mon Apr 28, 2014 5:30 am
Killtodie wrote:What do you mean by "not be replaceable inserts"?
As in not inserts, full replacement struts instead, like the stock rears of the alltrac. Also as you say, I thought they were too short to be used.
tw2
Postby Killtodie » Wed Apr 30, 2014 12:16 am
Pictures of the rear appear to be inserts. In the same pic they appear to be shorter as well.
I do not see anything but inserts for the rear.
I'll email KYB and get info from them on length and dampening resistance
Killtodie
Postby Killtodie » Wed Apr 30, 2014 1:35 pm
Reply from KYB
765015 Front
20.35” extended
14.02” compressed
13.3” body length
145/70 Setting 2 @ .3 m/s
765016 Rear
21.73” extended
14.92” compressed
14.17” body length
240/90
The rears are actually a bit longer than the fronts. I also dont understand where folks think the rears were full struts with spring seats, they are obviously inserts.
Info on regular Celica (non All-Trac) front inserts
365064 Front
19.57" extended
13.66" compressed
13.27" body length
120/30 @ .3
Killtodie
Postby MWP » Fri May 02, 2014 1:22 am
Killtodie wrote: I also dont understand where folks think the rears were full struts with spring seats, they are obviously inserts.
My KYB Excel-G's are full struts at the back.
Inserts at the rear are harder to install due to the tiny gland nut, you cant install an insert through it.
I know Koni get around this problem by using a bolt-through type insert.
Ie, you cut off the top of the strut, and the insert is bolted in through a hole you drill in the bottom.
Postby Killtodie » Fri May 02, 2014 8:51 pm
MWP wrote:Inserts at the rear are harder to install due to the tiny gland nut, you cant install an insert through it
Can you clarify on this?
Killtodie
Postby Killtodie » Wed Dec 10, 2014 8:08 pm
bump, I'm finally getting around to do this.
Would like to know if anyone has ever used MR2 rears all around, or flipped them. MR2 rear in front, and fronts in the rear.
Killtodie
Postby MWP » Fri Dec 12, 2014 12:47 am
To put inserts in the rear you have to cut about 2" off the top of the rear strut tube, and weld on the top 2" from a front strut tube.
Postby Killtodie » Fri Dec 12, 2014 3:54 pm
Yes, that's the plan. I picked up a blown set of struts to do this with.
Still would like to know why folks are using mr2 fronts
Killtodie
Postby Killtodie » Mon Dec 15, 2014 1:19 pm
Ordered MR2 fronts to be used in the rear, friend is going to assemble and weld them for me. Going to go with lowering springs. Should have them done next weekend hopefully.
I'll post updates, and pics
Killtodie
Postby Killtodie » Wed Jan 14, 2015 8:11 pm
Update:
Before welding.
I dont know what OP means where when he said not to order the MR2 rears for the front because something about the gland nut, I called KYB and verified with them that the gland nut is identical between 765015 and 16. So the MR2 rears will fit the front.
I still need to order them, currently using MR2 fronts for the rears. Will update as I go along.
Killtodie
Postby 88gt4DE » Thu Jan 15, 2015 11:48 am
Sweeeeet Almost there :smokes:
