ST185/ST205 Swaybar in a ST165
Postby Celica Turbo » Wed Feb 27, 2008 8:26 pm
Hello Guys
nothing found with "Search"
Are the swaybars from the ST165 and ST185 interchangeable?
Has anyone an idea or tested on theyre car?
thanks
Celica Turbo
Celica Turbo
Re: ST185/ST205 Swaybar in a ST165
Postby gpmarzan » Wed Feb 27, 2008 9:22 pm
Celica Turbo wrote:Hello Guys
thanks
Celica Turbo
Im pretty sure the rears are different, but im not sure about the fronts
Patrick M.
st165
gpmarzan
Postby WideFNopen » Wed Feb 27, 2008 11:10 pm
If that's the case then I am about to have a Whiteline st185 rear bar for sale....
Can anyone confirm that they are not interchangable?
https://www.facebook.com/peakcityrally
http://cdn.makeagif.com/media/1-12-2015/ZMp5Gn.gif
WideFNopen
Postby Gary ST165 » Thu Feb 28, 2008 12:10 am
i can confirm that whiteline st165 rear arb is unique and not interchangeable with st185/st205.
ST165 turbo 4WD
Gary ST165
Postby darthripley » Thu Feb 28, 2008 2:29 am
WideFNopen wrote:If that's the case then I am about to have a Whiteline st185 rear bar for sale....
i'm interested in buying if you're selling that whiteline 185 rear sway bar - PM me :D
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby Celica Turbo » Thu Feb 28, 2008 11:00 am
Gary ST165 wrote:i can confirm that whiteline st165 rear arb is unique and not interchangeable with st185/st205.
Hello
Here a picture from a ST205 (same ST185) swaybar
And here an ST165 sway bar
They are not the same but i think we can fit a ST205 swaybar in an ST165?
GTFOURS.co.uk says the rear suspension setup is similar from ST165, ST185 and ST205
What do you think?
The rear axle is same on the GTFOURs too..
Celica Turbo
Celica Turbo
Postby Gary ST165 » Fri Feb 29, 2008 2:04 pm
I personally have NOT tried the ST185/ST205 ARB for fitting.
I bought a replacement ST165 whiteline ARB. ( not yet fitted)
here are some pics that may or may not help you work out if the ST185 / ST205 ARB fits a UK ST165 with ABS.
ST165 turbo 4WD
Gary ST165
Postby WideFNopen » Fri Feb 29, 2008 9:11 pm
I am going to try fitting it into my 165 (non abs) this weekend and if it does not work then I will give you 1st dibs on it darthripley. I will let everyone know how it turns out.
WideFNopen
Postby darthripley » Fri Feb 29, 2008 9:26 pm
thanks widefnopen! good luck - i hope it works for ya :)
Female Moderator
darthripley
All Trac Goddess
Postby Celica Turbo » Mon Mar 03, 2008 10:35 am
any update?
best regards
Celica Turbo
Celica Turbo
Postby WideFNopen » Mon Mar 03, 2008 10:52 am
Sorry guys, I did not get a chance to mess with it this weekend. I should get it done this week. I will be sure to post up as soon as I figure it out what the deal is.
WideFNopen
Postby 935motorsports » Thu Mar 06, 2008 7:07 am
Long ago I tried to put an st185 whiteline swaybar on an st165. As you can see the st165 swaybar has a hump in it, to clear the body.
Now that whiteline makes an st165 swaybar, it is no longer an issue.
935motorsports
Postby syko says » Wed Feb 18, 2009 3:23 am
Celica Turbo wrote:Here a picture from a ST205 (same ST185) swaybar
Arise old thread!! :evil:
Is this fact? This is the only thread that I have found to say that the st205 rsb is the same as the st185 one.
Aloha,
Evan
syko says
Postby darthripley » Wed Feb 18, 2009 5:59 am
Meurz fit a C-One ST205 RSB into his CS awhile back :wink:
http://alltrac.net/phpBB2/viewtopic.php ... z&start=75
pg. 6 on the thread above. :)
Female Moderator
darthripley
All Trac Goddess
Postby Gary ST165 » Wed Feb 18, 2009 4:23 pm
Fact:
we have ran several group buys on gt4oc and ordered maybe 80 units in total. I confirm that the st185 and st205 share the same whiteline part # for the adj arb ;)
just fitted one fitted to my RC :D
:thumbsup:
ST165 turbo 4WD
Gary ST165
